B18C1 Timing Issue !!
Old 07-03-2008, 07:36 PM   #1
Rep Power: 0 JDMPalace is on a distinguished road
Default B18C1 Timing Issue !!
I did a GSR swap in my delsol and everything was fine till the distributor came lose (it only had two bolts on it) and then for some reasone the coil went bad. I ordered a new distributor and I installed it last weekend and the car fired right up. But I can't get the timing right. For some reason even at all the way rotated to advance the mark will only gets close to white line and not even between white and red so no where close to red where it should be, and the rpm is somewhere in 1100s. When I tried to retard it then it's not even close to white but then the car doesn't run right. I did jump the service connector but still it same case. In full advance the car runs fine in higher RPM but it just doesn't have the power it used in lower RPM.
Any thought why my timing is so off right now? Any help is appreciated !
JDMPalace is offline   Reply With Quote
Old 07-06-2008, 10:50 AM   #2
Boosted ls/vtec ohh yeah!
boostin4fun's Avatar
Ride:  EM1 EBP boosted ls/vtec, EM1 EBP Daily Driver
Rep Power: 18 boostin4fun has a spectacular aura aboutboostin4fun has a spectacular aura about
I would pull the timing belt and reinstall with a new one. The marks are probably a hair off right now, just enough for you to not be able to set the ignition timing correctly.
My build threads:
http://hondaswap.com/engine-building...c-build-84953/
http://hondaswap.com/engine-building...inished-92905/
I offer ecu socketing/chipping, tuning, swaps, and builds. PM me for details and pricing.
boostin4fun is offline   Reply With Quote
Old 07-08-2008, 04:01 PM   #3
Thanks, Thats what I was thinking too.
Any other opinion on this !!
Old 07-08-2008, 09:05 PM   #4
Rep Power: 4 thetunersource is on a distinguished road
hmmm maybe the timing belt is stretched or not to spec, but sounds more complicated than that
2002 Honda Civic Si Greddy Turbo'd
1989 BMW 328ci SR20DET Powered
1972 Honda CB350 Supersport
1971 Mercedes Benz 300sel 6.3 Monster
1989 Dodge Colt/Mitsubishi Mirage Turbo 4g63 Turbo'd -- goodbye, you will be missed
www.thetunersource.com
thetunersource is offline   Reply With Quote
timing belt issue crippleddave Civic and del Sol - EG and EK 11 01-27-2007 02:08 AM
HELP!!! 93 Si H22A Timing Issue? Won't Run Right Nixon0426 Prelude 2 01-25-2007 01:31 PM
Timing issue. 90_civic_Si Civic and CRX - EF 2 10-11-2006 06:39 PM
I Think i have a Timing Issue poops87 Engine Building 6 02-28-2006 03:56 AM
b16 timing belt issue DelSlo HYBRID -> EG-EK / DC 3 01-14-2005 02:39 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
