B18c5 In 88 Crxdx Will There Be Room 4 Turbo?>? T4
Old 02-03-2003, 02:35 PM   #1
Rep Power: 14 88crxdx is off the scale
ok i need to know if there will be room for turbo t3t4 in my crx with a b18c5?? maybe a little nos if i go insaine. but let me know thanxs.
88crx dx
pearl white
silver enkei rims
b18c5 and the rest is up to you when we race.
wings west body kit
DONT THINK, JUST DUMP IT
88 dx crx
pearl white
88crxdx is offline   Reply With Quote
Old 02-03-2003, 02:43 PM   #2
Rep Power: 15 Nerologic is off the scale
there is enough roon if u use the new mount kit from hasport..i think u will also have enough room with the old hasport and the placeracing one but if u modify the mounts and use integ mounts to get the b18 in the engine bay u will have a hard time installing that setup...
*big ass worthless pic removed*
Nerologic is offline   Reply With Quote
Old 02-03-2003, 02:59 PM   #3
GNU/Linux Evangelist
lsvtec's Avatar
Ride:  The Cheapest Road Bicycle I could get
Rep Power: 69 lsvtec is on a distinguished road
Why do you want to turbo the C5? It is already on the way to being a killer NA engine. If you want to boost start with a C1.
v3sw7+9Chw6ln3pr7Ock4ma9w3TXm3l7GDF i7Ce6+8t4MNb8Oen6g6RAOa26s5MRp6 hackerkey.com
lsvtec is offline   Reply With Quote
Old 02-03-2003, 03:05 PM   #4
I DUNNO WHY BECAUSE I GO CRAZY ABOUT SPEED AND JUST WANT TO KEEP GOING FASTER.. OR SHOULD I NOT HAVE TURBO AND JUST HAVE NOS
88 dx crx
pearl white
Old 02-03-2003, 03:09 PM   #5
Rep Power: 83 Havok is an unknown quantity at this point
Send a message via AIM to Havok
you should stop writing in CAPS and stop posting it twice.
My skin is singed but it heals my heart
and with glowing pride I'll wear my scars.
I'm honored by your hatred!
She wanted love, I taste of blood.
She bit my lip and drank my warmth from years before.
Havok is offline   Reply With Quote
Old 02-03-2003, 03:24 PM   #6
lsvtec's Avatar
You need to calm down first. I was n't questioning why you want a turbo, only why you want to turbo the C5? The C1 is a better 1.8L VTEC engine for turbo. If you plan on boost you have some serious reading ahead of you before you start buying anything.
Old 02-03-2003, 06:14 PM   #7
Arrow
Originally posted by lsvtec+Feb 3 2003, 03:29 PM--><div class='quotetop'>QUOTE(lsvtec @ Feb 3 2003, 03:29 PM)</div><div class='quotemain'> <!--QuoteBegin-88crxdx@Feb 3 2003, 01:10 PM
You need to calm down first. I was n't questioning why you want a turbo, only why you want to turbo the C5? The C1 is a better 1.8L VTEC engine for turbo. If you plan on boost you have some serious reading ahead of you before you start buying anything. [/b][/quote]
so you are saying the c1 would be better for turbo and nos?? why would it be so difficault for the c5?? or what if i just supercharged the c5 . you tell me?? what would be faster.???
88 dx crx
pearl white
Old 02-03-2003, 06:26 PM   #8
Rep Power: 23 chet is off the scale
Send a message via AIM to chet
ok, i will go into the details about why a gsr motor is a better platform for turbo, because i really think it is..and i've seen guys with stock itr bottom ends pushing 8psi, and i've seen guys with rebuilt bottom ends pushing 14 psi.
first, the b18c5 has very aggressive cams, and has higher compression which is not always desireable for turbo. so in essence, your'e taking a motor honda specifically designed to get peak hp out of through higher compression and aggressive cams and putting a blower on it.
second, the type r transmission is very short, and in my opinion too short for turbo. the gsr transmission, although lacking LSD, is geared ideally for turbo and has a strong differential, stock. not as strong as itr, but strong enough to withstand 250plus hp when driven intelligently.
now, when looking at a gsr motor, it has cams that most people switch to when going turbo, as the lobes lend themselves to a duration that makes good power. its compression is also lower, which makes it easier to run more psi on a stock bottom end without worrying about doing too much damage.
now a supercharger is completely different, and its the route i'd go if i were going to force more air into my motor. however, if i could get my hands on a type r motor, i'd just put cams in it and rev the hell out of the bottom end.
this should answer your question.
<a href=\'http://www.geocities.com/coker_boy/honda.html\' target=\'_blank\'>The Green Machine</a>
chet is offline   Reply With Quote
Old 02-04-2003, 11:50 AM   #9
so what would be faster? turbo the b18c1 or leave the b18c5 for raw horsepower?? what tranny do you think is better out of the 2? will supercharging the b18c5 be difficault>?
88 dx crx
pearl white
Old 02-04-2003, 12:46 PM   #10
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 541 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
are you honestly asking if a boosted GSR will be faster than a NA ITR?????
please tell me your not serious
any respectable turbo setup should kick the shit out of a natrally aspirated car... there are exceptions but not many
and dont even bother supercharging an ITR engine it is meant to be run NA... its designed to be run NA... the only reason to bost an ITR engine instead of going with a GSR engine is for the "bling" factor of saying "i gotz me a boozted type R y0!"
МОΛΏΝ ΛΑΒΈ
E_SolSi is online now   Reply With Quote
Old 02-04-2003, 01:26 PM   #11
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Hmmm....Did you read what was posted?
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 02-04-2003, 04:38 PM   #12
so just turbo the b18c1 sounds good. one more ?? why is the tranny's of the 2 so diffrent?
88 dx crx
pearl white
Old 02-04-2003, 04:58 PM   #13
Rep Power: 14 b20civic is off the scale
Do a search for honda transmission gear ratios, compare the two and you will notice the close gear ratio of the the type R....This is good for nitrous or N/A but not for turbo....with a turbo you want to be in the gear longer to utilize the boost.
b20civic is offline   Reply With Quote
Old 02-04-2003, 05:03 PM   #14
i wrote an article on b-series transmissions.
here is the link, and i'll paste what is written within the article.
http://www.hondaswap.com/articles/viewer.php?id=45
B-series Transmissions
In response to recent questions about different transmissions I think its important to shed some light into the ones available for our b-series motors. There are many differences between B-series transmissions and I've never found an article describing the positives and negatives of each unit. Below, you'll see transmission codes, the car it's found in, and whether or not it has factory LSD. It's important to realize that Honda didn't make it easy for us to distinguish between transmissions. For example, almost all transmissions found in Integra's are stamped S80. This includes the tall LS transmission and the ultra short JDM Type-R transmission. In some cases, the only way to determine which transmission you really have is to take it apart and count the number of teeth on the ring gear. Obviously, in most cases it's not practical to take your transmission apart to determine which one you have. To be safe when acquiring a transmission, you should identify the seller; try to identify the car and or motor it came with.
B16A (Cable), B16A2 (Hydro), B16A3(Hydro):
S4C, S80, Y80, Y21, Y1 (optional LSD)
As most of you know the B16A was featured in Japan between the years of 1989 through 2001. This engine has had several different transmissions mated to it causing some potential confusion.
First, it's important to realize that first generation B16A's came with cable transmissions. The Y1 came with optional factory LSD and should have LSD stamped on the transmission. Determining whether or not a transmission has LSD is very simple, just look into the differential and see if its opened or closed. For those not familiar with this, you'll either see a set of gears that form a closed cylinder, or you'll see an open differential with a bar splitting the middle.
Typically these transmissions have had weak synchro's in 2nd, 3rd, and 4th gears with 3rd gears crunching the most. Its also worth noting that all of the transmissions minus the Y1 have very weak open differentials making it essential that you upgrade if your putting a lot of power to the ground.
As far as gearing, these transmissions are all pretty short. Here is a listing of the gear ratios and final drive, courtesy of www.bseries.net.
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3.000
Final Drive: 4.400
In conclusion, this transmission is good for all motor and should bring between 500-700 if its hydraulic while cable transmissions are worth between 400-600. Please be careful that the transmission you're buying doesn't have bad synchro's because a lot of them have been beaten on and this is the first problem you'll have. Plus, if you're making a lot of power, 170 to the wheels, be prepared to replace your differential because these can be broken with regularity.
B16B (Hydraulic):
S4C (LSD)
The transmission found in the Civic Type R is highly sought after and very rare. Its gear ratio's are identical to that of the B16A's but has a stronger limited slip and dual synchro's in 2nd, 3rd, and 4th gears. Expect to pay between 1000-1200 for a genuine CTR transmission because they're rare and well worth the price. Its also worth mentioning that these transmissions are Hydraulic type.
B17A1 (Cable):
YS1
This transmission is found on the rare "blacksheep" of b-series motors. The most important feature here is that its cable-type. This means you can bolt this into any 93 and older integra and 91 and older civic without having to change to hydraulic. The synchro's on this transmission are still considered weak, however the gearing is very good for all motor applications as its identical to the B16A transmissions. Finally, this transmission did not have factory LSD, so keep that in mind when someone is trying to tell you otherwise. Look to pay between 400-600 dollars for this transmission, although its going to be difficult to find and usually when you do, there is something wrong with it.
B18A1 (Cable):
YS1
Again, you'll see how Honda didn't help us out any with the stamping on this transmission. These transmissions however, are much different in there gearing. This transmission has a longer first and second gear with slightly longer 3rd and 4th gears. The final drive is still 4.40:1 making this a possibility for all motor applications, but not your best choice. You'll be able to find this transmission in 90-93 Integra's and they're all cable-type. The prices for these should range between 200-400 for clean, good working units. Paying anymore is pointless, as these transmissions are everywhere.
B18B1 (Hydro):
S80/Y80
This is probably the easiest b-series transmission to find because it's found in every non-VTEC 94-01 Integra. Most notably, this transmission is the longest of all b-series transmissions and has the weakest synchro's and weakest differential. The final drive is 4.266:1 and each of the gears is longer compared to its B16A counterparts. For boost, a lot of people like the gearing of this transmission, plus gas mileage is great and they're very cheap. Look to pay no more than 500 for a clean LS tranny because they're everywhere.
Here is a look at the Specs.
1st: 3.230
2nd: 1.90
3rd: 1.269
4th: 0.966
5th: 0.714
Reverse: 3.000
Final Drive: 4.266:1
B18C:
S80/Y80 (Optional LSD)
The transmission found in JDM GSR's is very popular and overall an excellent transmission. For all motor and boost applicatiosn this transmission has excellent gearing and a stronger differential compared to its B16A and B18B counterparts. The transmissions with LSD should have "LSD" stamped on the casing and to make sure, inspect the differential and use the parameters I described before to identify whether or not the transmission really has LSD. Look to pay between 700-1200 for this transmission depending on whether its LSD equipped. Also worth mentioning, these transmissions are all hydraulic.
Here is a look at the specs:
1st: 3.230
2nd: 1.900
3rd: 1.360
4th: 1.034
5th: 0.787
Reverse: 3.000
Final Drive: 4.400
B18C1:
Y80
This transmission is found in all USDM GSR's. Although LSD was not offered these transmissions are still highly sought after because of their stronger differentials and optimal gearing. For those not interested in ultra-short gearing this transmission provides the perfect balance between acceleration and top end. Look to pay around 700-1000 for these transmissions.
The specs are the same as above:
1st: 3.230
2nd: 1.900
3rd: 1.360
4th: 1.034
5th: 0.787
Reverse: 3.000
Final Drive: 4.400
B18C5:
S80 (Helical LSD)
This transmission is one of the best B-series transmissions Honda has offered in its vehicles. Every gear has dual synchro's and the gearing is perfect for all motor applications. Plus, LSD is standard and will be stamped on the housing. Look to spend between 1200-1400 for these transmissions because of their quality, LSD, age and gear ratio's. Finally, if there is some question about whether or not you're S80 has 4.4 final drive or 4.7 final drive you can check the transmission housing. The code "4jhd" means 4.4 final drive was offered as original equipment, while "ne3" signifies 4.78 final drive.
The specs are below:
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.107
5th: 0.848
Reverse: 3.000
Final Drive: 4.400
B18C (JDM Type R):
S80 (Helical LSD)
JDM Type R transmissions are the best for all motor applications where acceleration is emphasized most. All 98 and up JDM Type R transmissions came with 4.785 final drive with the same 1st, 2nd, 3rd gears as the USDM Type R. To make highway driving more tolerable, the 4th and 5th gears are the same as GSR transmissions. Look to spend between 1400-1600 for these transmissions because of their final drive and rarity.
1st: 3.230
2nd: 2.105
3rd: 1.458
4th: 1.034
5th: 0.787
Reverse: 3.000
Final Drive: 4.785
Conclusion
What a chat......don't read if you have a life Airjockie Members' Lounge 6 01-02-2004 12:21 PM
last nights chat pissedoffsol Members' Lounge 22 12-03-2003 02:56 AM
Wiring Harness For B18c5 hondacivicnos HYBRID -> EG-EK / DC 13 03-10-2003 04:51 PM
Wiring Harness For B18c5 hondacivicnos ECU's, Electronics, and Tuning 1 03-09-2003 01:35 AM
Boosting B18c5 GSRCRXsi General Tech and Maintenance 23 01-14-2003 06:23 PM
