B18c5 In 94 Civic Ex
Old 06-02-2003, 10:12 AM   #1
rmb2k is off the scale
I have a 1994 civic ex. I would like to know the pros and cons of this idea I have. The current engine has close to 135k miles on it. What I would like to do is replace it with the B18C5. I have done a small amount of research and it seems that this is a direct swap. On the other hand my dad thinks that a turbo or supercharger would do just fine. My problem with that is I don't want to spend money on something for my engine since it has so many miles. What do you guys think? B18C5 vs. Turbo/Super charger??? how does the amount of hp compare with each choice?
Thanks
Ryan
rmb2k is offline   Reply With Quote
Old 06-02-2003, 12:46 PM   #2
deth101 is off the scale
Send a message via MSN to deth101 Send a message via Yahoo to deth101
c5's are wicked cool but $$$$$ and any swap has some complication that seems to make "drop-in" not apply,even v-8 swaps....on the other hand turbo or supercharging that D is not gonna give you the results you will like unless you put a huge turbo on,any B series is a good idea in my opinion very buildable.....spend more time reading about the pros and cons of these engines and the c5 might drop off your most wanted list for future upgrades,of course it is a beauty though
</span><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE </td></tr><tr><td id=\'QUOTE\'>QUOTE (pyrohardcore @ Apr 22 2003, 06:56 PM)guess i'm sorta out in the open surrounded by fat kids in paintball tho </td></tr></table><span class=\'signature\'>
Evil Should'nt Look This Good.
deth101 is offline   Reply With Quote
Old 06-02-2003, 02:39 PM   #3
nuc79 is off the scale
Send a message via AIM to nuc79
You can spend about $2k for a D-series turbo kit and have almost as much horsepower as the bone stock $4000 typeR motor. However, you will hit the limit much faster on how much HP you can squeeze out of the D16Z6. If you wanted to get a B-series later on, all you would need to get to set up the turbo kit for the new engine is a B-series turbo manifold and possibly upper IC piping(if you get a B18C). Go turbo now, get swapped later. Why spend the extra $2k when you might be happy with just a turbo? And IMO, it's much easier to bolt on a turbo kit than swap an engine.
My Honda Chronology: 90 Civic(traded), 88 CrxSi(totalled), 90AccordLXcpe F22A1turbo(still own, soon to be H23A1turbo), 94 GSR4dr(traded), 01Civic(traded), 89ZCsedan(traded 6/03 for 2 CRXs), 93CivicEX(sold 7/03), 99OdysseyLX(still own)
nuc79 is offline   Reply With Quote
Old 06-02-2003, 02:51 PM   #4
vtecsir1 will become famous soon enough
plus i hope you wouldnt just throw a turbo on a motor that has that many miles, you would be asking for it to die then. get the r motor i think you would be happier in the long run and ofcourse more power can be made.
vtecsir1 is offline   Reply With Quote
Old 06-02-2003, 04:18 PM   #5
JDMilan is off the scale
I would go with the R motor. If you want to boost down the road then get a GSR motor.
Milan
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 12:03 PM
Decoding VIN Numbers pissedoffsol General Tech Articles 0 01-11-2004 07:48 PM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 03:43 PM
All This Reference Material, And No Cel Code Chart Slo86GT Members' Lounge 5 06-13-2003 09:31 AM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 04:32 PM
