B20 Swap information
Old 04-05-2004, 02:31 PM   #1
Rep Power: 0 mcash is off the scale
Looks as though my B18 (95 Integra LS) is on its way out. Starting to have some oil burning problems. So, since I am looking to upgrade anyways, I thought this might be a good time to do so...
Does anyone know of any good sources for B20 swap information? (I did search on the forums here) What I am paritcularly worried about is electrical problems that may occur between the B18 vs. B20.
Local aftermarket shop suggested this swap as opposed to some of the other idea's I was kicking around.
From looking at the engine spec's it looks relatively compariable to the B18 as far as raw power (stock NA). Any opinions on the B20?
Any information/opinions on this swap would be greatly appreciated.
Thanks in advance.
Mike
mcash is offline   Reply With Quote
Old 04-05-2004, 02:46 PM   #2
By the way,
I did read this post. Which I think accurately describes the swap.
http://www.hondaswap.com/forums/inde...howtopic=29809
Having an LS already, it "appears" as if the swap with for the most part bolt right on up.
Just want to know if there is anything else that needs to be considered. Also, I didnt post it in the last post, but I plan on building the B20 as a turbo'd engine when I get to that point.
Mike
Old 06-02-2008, 04:30 PM   #3
Rep Power: 0 91gra_xsi is on a distinguished road
im going through the same process my 95 ls motor is going away and im proly going to put a b20z in it...... i had already converted my ls to obd1 and i know that the b20z is obd2 so all i need to to is switch the ob1 components from the ls to the b20 and thats it drop it right in there right? or do i need other things to do?
91gra_xsi is offline   Reply With Quote
Old 06-02-2008, 07:37 PM   #4
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
Idiot. This thread is from four years ago. Please check the dates on stuff before you post from now on...
PSN Network ID: BrutalB83
Who ever completed a ZC swap in CRX Si KYL174 HYBRID -> ED-EF / DA 6 04-09-2007 10:34 PM
Del Sol S D15B7 to D16y8 swap question oakley2002@cox.net HYBRID -> EG-EK / DC 1 01-21-2004 01:32 PM
2nd gen Integra Swap Info pissedoffsol Swap Articles 0 01-12-2004 02:16 AM
1st gen Integra Swap Overview (da) pissedoffsol Swap Articles 0 01-12-2004 02:15 AM
