B20B from CRV into 92-95 Civic SI SWAP
Old 10-06-2003, 04:38 PM   #1
Rep Power: 16 hondacivicnos is off the scale
Thumbs up
Yo I am just researching stuff for civic's swap and I run into some questions about B20B swap.
As far as I think its the cheapest swap for Civic and with turbo it should be around 160-180HP.
But I still dont understand if the OBD2 is some much trouble for civics with OBD1 why no one in swap guide tell anything about it.
B20B is a OBD2 engine and civic's are obd1, what do ppl do to make it work with civic harness?
Thats pretty much it for now, thanks
<span style=\'color:yellow\'><span style=\'font-size:21pt;line-height:100%\'><span style=\'font-family:Times\'>yo what up dawgs</span></span></span>
hondacivicnos is offline   Reply With Quote
Old 10-06-2003, 04:41 PM   #2
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
Rep Power: 31 saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
use a obd1 intake mani from a ls.
saturn_boy96 is offline   Reply With Quote
Old 10-06-2003, 05:25 PM   #3
Thumbs up
thats it? What about distributir or what ever its name is.
Old 10-07-2003, 01:10 PM   #4
common ppl I need some help about this!!!
What about OBD differences?
B20Z is OBD2
Civic is OBD1
How does it work, do I have to do all that rewiering stuff for OBD2 to work on OBD1?
Please tell me!!!
Old 10-07-2003, 01:37 PM   #5
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
Umm, I think you can just use ur stock wire harness, and run a obd 1 integra ls ECU, but u have to change the Intake manifold to an LS because the b20 is too high to clear the hood, and the distibutor should be ok, if the plugs don't match up just splice it into ur harness. It's should be pretty easy.
With a turbo you'll push alot more that 160-hp, Let's say u were usin 8 psi, you'd have at least 200. Ls's are smaller displacement and w/ turbo get more than 200 if tuned right.
IMO just buy a b18b1, its cheaper, and only has 4 hp and 6 lbs tq less than the b20, if you really want that extra hp, bore the b18 out to 83-84 mm.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 10-07-2003, 06:22 PM   #6
Exclamation
Thanks bro!!!
Old 10-08-2003, 12:33 PM   #7
if you wanna bore it and run turbo tho, you need to get that thing sleeved first.
but good luck on the build, sorry i forgot about the distributor.
92 civic hatch with integra LS swap / lambo doors troyer4k Vehicles: For Sale/Trade/Wanted 21 11-01-2004 05:06 PM
Help me choose Civic for engine swap arielb1 General Tech and Maintenance 16 06-17-2004 11:59 AM
01 Civic SI - What can I swap Stanage HYBRID -> EP / DC5 8 05-11-2004 01:44 AM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 04:43 PM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 05:32 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
