i have a 96 b18b in my 96 ek. i had a turbo d16y7 in it before i swapped it out. my exhaust is 2.5" all the way back to a ractive muffler. i have NO cat or test pipe or any thing. is this bad cars runs fine but hesitates a little when i take off and also when iam in like 3rd gear at like 2000 rpms and go to punch it it hesitates as well. but once i get passed like 3500 rpms i pulls like a mo fo.
1) would this problem be due to not enough back pressure? 2) what can i do to fix it? please help. thanks in advance to any one who helps me |
2.5" is fine for your setup. The whole backpressure being needed idea is a myth, what is lost with piping that is too big is exhaust velocity. Even so you should be fine with that size. It sounds to me like you may have an ignition problem, have you changed the plugs, wires, cap and rotor recently? Any CEL or codes stored in the ECU?
-Doc |
Admin with a big stick
Ride: 2003 S2000
Yaaaay someone else that at least has a basic grasp of fluid mechanics...
#4 | |
![]() I checked out your website, looks like you've got a nice shop. If you ever have Toyota swaps come in and need the wiring done quick and cheap, let me know. All the details are on my website: Phoenix Tuning - Home -Doc |
#6 | |
FüK-VTEC
Ride: 07 Nissan Frontier, 90 CRX Si, 06 ZX6R racebike, chopped-out 02 Yamaha V-Star
#12 |
thanks guys for all the help. ill let you know what happens. with my problem.
one more thing. does anyone have base setting for a safc 2 on a b18b with t3 turbo and dsm 450s and a tial external wastegate set at .7 BAR (10 psi). if any one does will you be willing ot hsare them thank you |
#13 | |
FüK-VTEC
#15 | |
FüK-VTEC
SAFC's and FMU's are hacks, and while they may work temporarily, in the long run you'll end up breaking something. I'm sure someone will post here saying 'oh buy my friend's brother's uncle's sister's cousin is boosting 30psi on an ITR daily driven with only an FMU and an SAFC'...but that kinda speaks for itsself, if you know what I mean. Do it the right way, or don't do it at all. It'll pay off in the long run to wait until you can do it correctly. |
#16 |
ok thanks. heres what iam gonna do. iam gonaa convert to obd1 using only a obd1 p75 ecu and a obd2a to obd1 harness. after that how do i go about getting the ecu tuned to match the injectors and also to run 10 psi. in other words after converting to obd1 what do i need to do to get it tuned to 10 psi and be safe and reliable
#17 | |
FüK-VTEC
What part of the US are you in? |
#18 | |
Ride: 2003 S2000
![]() __________________
| busted back end | 91TurboCivichb | Wheels / Suspension / Tires / Brakes | 2 | 11-06-2005 03:42 AM |
| Fuel Pressure Question | dhondagini | General Tech and Maintenance | 8 | 09-26-2003 03:28 AM |
| Crx Tire Pressure Question | sportlinecrx | Wheels / Suspension / Tires / Brakes | 4 | 01-05-2003 02:28 AM |
| Back Pressure............ | RoadRage | Engine Building | 10 | 10-18-2002 06:01 AM |
| Breaking it Back in... | Slo86GT | Forced Induction | 13 | 10-02-2002 10:23 PM |
