Ride: 1994 HONDA CIVIC VX WITH A D16Z6
it goes away when i push the clutch in but when i let it out it comes back,,when you get going and step on it it comes back
GROUND RUBBIN ![]() 94 CIVIC VX W/ SWAPPED D16Z6 |
Ancient Member
Ride: RHD EG6 jrsc b18c :)
probably your transmission mainshaft bearing, you could try just replacing the throw out bearing, but I would assume that it is the bearings inside the tranny
9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6 doing it myself! 6/1/09 RHD on the road, now time for Body Shop 7/10/09 jackson gsr into rhd+hondata 91 rex ls/vtec b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER! 13.881@102 on street tires Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some reptation, then give 'em a point!---, <-------------------------------- |
| Miata Pilot bearing questions | Guy | Other Vehicle Discussions | 14 | 11-09-2009 05:32 PM |
| wheel bearing | mholmes85 | General Tech and Maintenance | 8 | 05-20-2006 08:46 AM |
| Bearing sizes.. | Crix | Engine Building | 5 | 01-05-2005 10:37 AM |
| crank bearing spun!!! CRX | jpoenitsch | Engine Building | 7 | 06-01-2004 04:18 PM |
| Spun A Rod Bearing After 6000 Miles! | habitforming | Engine Building | 14 | 01-09-2003 10:49 AM |
