Ok I'm getting ready to put in my b18c5 but I need to replace the belts....all of them. Problem is I don't know exactly what I need. I have the timing belt but what other belts do i need to get (alternator belt, compressor belt etc). Anything else I should get while I'm out? I figured a new water pump but I can't think of anything else.
general rule of thumb
replace: water pump, timing belt, tensioner, ac/alternator/ps belts, upper/lower hoses, heater core hoses, thermostat, valve cover gasket & spark plug grommets, as well as spark plugs, plug wires and dist. rotor and lastly the dist. cap. this is stuff that i replaced when i swapped my b20b into my integra. I havent had any problems with it since. __________________
90 Integra Sedan B20V 225 / 153 I DO NOT answer tech questions via PM. Use the forums!!! |
