Blox block guard
Old 10-31-2009, 11:17 AM   #1
Rep Power: 0 Egturbohatch is infamous around these partsEgturbohatch is infamous around these parts
Default Blox block guard
sup im just wondering if any 1 have use the Blox block guard............is it worth buying or mind as well get the golden eagle 1s....let me kno......any advise and comments please
Egturbohatch is offline   Reply With Quote
Old 10-31-2009, 01:33 PM   #2
Dark93DX's Avatar
Rep Power: 10 Dark93DX is on a distinguished road
Why do you think you need it?
K20Z3 EG - Installed, waiting for Kpro
LSD w/ 4.764 FD
B18A CRX
Dark93DX is offline   Reply With Quote
Old 10-31-2009, 03:24 PM   #3
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
Install the block guard first, and then have the block bored and honed. I've heard from a reputable source that just installing the block guard will actually cause the cylinder bore to shrink at the top of the sleeves. This can cause premature ring wear.
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 10-31-2009, 06:55 PM   #4
B
Administrator
B's Avatar
Ride:  318ti, dakota, genesis 2.0t
Rep Power: 403 B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
I would advise against using any block guard.
Originally Posted by Airjockie View Post
I got plenty of duck tape, but no penguin tape...
B is offline   Reply With Quote
Old 10-31-2009, 06:59 PM   #5
Ride:  1991 civic hatch dx
Rep Power: 5 Bobby17772 will become famous soon enough
yeah just save your money and get it resleeved
Bobby17772 is offline   Reply With Quote
Old 10-31-2009, 08:45 PM   #6
D-Series Ninja
riceracerex's Avatar
Ride:  90' Honda CRX Si
Rep Power: 11 riceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the roughriceracerex is a jewel in the rough
myspace
Thanks for the good info, What are the best prices for sleeves? Dartons are the only ones I know of...
riceracerex is offline   Reply With Quote
Old 10-31-2009, 09:29 PM   #7
B
Administrator
B's Avatar
myspace  FaceBook
Bensons, golden eagle, JG, and a bunch more do sleeves
Old 11-01-2009, 12:37 AM   #8
D-Series Ninja
myspace
Wet sleeves are better better than dry I am guessing?
I WANT!! They are not cheap tho.
Old 11-01-2009, 04:54 AM   #9
dont have the money to sleeve........tell u the truth i dont kno why im buying a block guard but i guess it would help the cylinder not to walk....i guess....
so like i said on my other post im tryin to build a ls turbo mildy/fully build........so wat should i do about the machine shop....wat should i get done dat is needed...wat type of work?....my rings r blow, if dat helps.........does it cost anything for the shop to give u a qoute on the work dat might be needed and for them to inspect for any defects...and dats base on me bring the block to them.....
so u guys never answer my post....wat u think about the Blox blokk guard?
thank u
Old 11-02-2009, 07:44 PM   #10
D-Series Ninja
myspace
I would think it would be cheap and ineffective compared to sleeves. Blox is like the APC of tuning products. You can find Darton Sleeves as low as 200.00 Shipped but if you want to go ahead and spend the money on a guard then I don't think it would really matter if it was Blox or a generic Ebay Block Guard.
Old 11-04-2009, 01:09 AM   #11
so wat exactly these block guards do?....and any block guards are good?/..good looks
Old 11-04-2009, 01:15 AM   #12
B
Administrator
B's Avatar
myspace  FaceBook
most sleeves crack from the center...not from the top... where the rod/stroke angle is at its worst angle pushing sideways on the sleeve.
the block guard only goes on the top, and thus, it blocks water flow, which leads to more heat, detnoation, and doesn't even effect the problem area-- the bottom of the stroke.
You're honestly better off without the block guard.
Old 11-04-2009, 05:08 AM   #13
D-Series Ninja
myspace
What about using Devcon B? You can cover both areas but I don't know if it shrinks and expands as well as the actual block. I have been considering this if it is better than sleeves but I doubt it. Maybe better than using a block guard tho?
Old 11-04-2009, 05:09 AM   #14
B
Administrator
B's Avatar
myspace  FaceBook
everyone i know who tried it blew up....
Old 11-04-2009, 05:10 AM   #15
D-Series Ninja
myspace
Oh, fuck that then, Why have so many people went with that route?
Old 11-06-2009, 11:33 PM   #16
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
People choose that route because it seems like a cheap way to make higher power than on stock sleeves.
In reality, the money spent on a block guard can be better spent in other areas of a build.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 11-07-2009, 12:35 AM   #17
D-Series Ninja
myspace
I see, well I have never had a problem with stock Honda sleeves so I will trust they will hold.
Old 11-07-2009, 04:27 AM   #18
Dark93DX's Avatar
Blockguard = fucking waste of money
Either boost it stock, keep it mild, and hope you don't ever get the desire to crank the boost up.....or build it to handle the power you really want.
LSD w/ 4.764 FD
B18A CRX
Old 11-07-2009, 10:11 AM   #19
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Like better tuning so that you WON'T need a block guard.
Old 11-07-2009, 01:54 PM   #20
D-Series Ninja
myspace
I do get greedy so what will be the limit on stock sleeves? Is it hard to tell usually? None of the engines I have built ever blew up but they were all n/a. I have seen 30lbs and one of the pistons actually went bad before the sleeves did.
Old 11-07-2009, 07:24 PM   #21
F.I. Junkie
What he said
The limit is going to depend on the tuner honestly. There have been stock sleeve B-Series builds well into the 4's that have lasted for quite some time. There have also been many that went well into the 4's and lasted for only seconds. The difference is in the tuning.
-320 WHP EJ6-
Old 11-07-2009, 08:27 PM   #22
D-Series Ninja
myspace
Great explanation. I am tuning myself but always take every precaution before a modification. The software I have is TurboEdit OBD0 so it has it's limits and hopefully I can upgrade to OBD1 soon.
Old 11-12-2009, 03:17 AM   #23
im tryin to build a Ls turbo and looking to get a daily driver wit atleast 400whp so do i need to get sleeved?.....
wow! i didnt really kno blokk guard is useless according to wat u guys is saying but otheres say it's good for cooling and help wit the cylinder walk or somethin like dat
Old 11-12-2009, 03:25 AM   #24
D-Series Ninja
myspace
Been reading alot about Block Guards and Filling the blocks lately and it looks like neither of them are good options for a DD. I don't think you would need sleeves as long as it will be tuned properly. Are you going to attempt a Ls/Vtec Turbo or just the LS?
"¿ʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı" uɐɯ ǝlqısıʌuı uɐ ɟo sɹıoɯǝɯ ɯoɹɟ ǝʇonb ɐ ɟo pǝpuıɯǝɹ ɯ,ı
Old 11-15-2009, 11:45 PM   #25
nah no vteC, just straight Ls turbo...just want to be a lil differ den some peeps...so im getting close to pulling my motor out, wat u guys think i should let the machine shop do...for the records this is my first build......i got a Ls possibly wit blown rings, im going straight Ls turbo mildy/fully build.....let me kno where to start and wat should i get done the the motor, and please dont tell me go Ls/vtec, and vtec is better but this is wat i want......
thanks!!!!
Blox block guard civic d16y d16z d15 d16 RSS-Bot Auctions 0 08-30-2009 12:17 AM
Blox block guard civic d16y d16z d15 d16 RSS-Bot Auctions 0 08-20-2009 03:17 AM
Blox block guard civic d16y d16z d15 d16 RSS-Bot Auctions 0 07-02-2009 03:03 AM
Blox racing block guard b16 honda civic integra crx jdm RSS-Bot Auctions 0 03-24-2009 07:03 PM
Blox racing block guard b16 honda civic integra crx jdm RSS-Bot Auctions 0 12-06-2008 06:36 PM
