| | LinkBack | Thread Tools |
| | #1 |
| Junior Member | Hey Ive got a 91 civic AWD wagon with a blown motor(I know its a dorky wagon but it goes great thru the snow) I also have a wrecked 89 CRX with a good 1.5(the 2 injector intake) can I bolt the 1.5 into the wagon and use the 1.6 intake on the 1.5?...will it bolt in? I also have a 89 integra, would that motor fit? thanks for any info. |
| | #3 | |
| Admin with a big stick Join Date: Sep 2002 Location: Dallas / Fort Worth, TX Age: 32
iTrader: 0 / 0% Ride: 2003 S2000
Rep Power: 392 | Quote:
Tubby- you should be able to drop in the 1.5L block and use your 1.6L head and original transmission- I assume it's the D16A6? | |
| | #5 | |
| | #9 |
| RETIRED | basically, what you are doing is a reverse mini me - kinda sorta - instead of going from the 1.5 and putting on the 1.6 head on it, you have the 1.6 block and are putting the 1.5 block on it. go for it man- it may turbo out to be a little faster too! |
| | #10 |
| Senior Member | keep the intake manifold from the wagon so you do not have to do a MPFI (multipoint fuel injection) to DPFI (dual point fuel injection) swap. just swap the blocks if possible, the heads should be the same, but the cams in the 1.6l are more aggressive. good luck man. |
| | #12 |
| Senior Member | i'm kinda new to the tuner market but seeing how the 89 teg is a dohc and has the same motor mounts as the civic and knowing it easily swaps in why just not swap the teg's into the civic and pimp that?DOHC and AWD sounds good to me. |
| | #16 | |
| Senior Member Join Date: Sep 2002 Location: Baltimore, MD Age: 25
iTrader: 0 / 0% Ride: '92 Civic CX
Rep Power: 40 | Quote:
| What else should I replace if doing head gasket? | ssl2k | Engine Building | 6 | 04-14-2004 11:30 AM |
| Replace good looking Timing Belt?? | Citizen_Insane | General Tech and Maintenance | 20 | 03-27-2004 11:12 AM |
| How to replace your LCA bushings. | 92b16vx | Wheels / Suspension / Tires / Brakes | 7 | 03-09-2004 05:41 AM |
| D15B7 to Replace D16Y7 | Johnnylawless | Engine Building | 3 | 01-09-2004 05:03 AM |
| cylinder head replace | hondacivicjosh | Engine Building | 1 | 09-29-2003 03:21 PM |
