can i swap parts from a D16 to a D15B
Old 01-05-2005, 02:03 PM   #1
Rep Power: 13 evo8 is off the scale
Send a message via AIM to evo8 Send a message via MSN to evo8
Thumbs up
i found this link on HMO for there d15b longblock.
http://www.hmotorsonline.com/shop/sc2000se...page&item=30019
since i have a d16 in my 95 civic already, could i swap the transmission(5 speed), axels, ecu, fit on stock motor mounts, wiring harness, and other things and have it work perfectly. if not what would i need that i cant get from my D16? also, would i be able to swap out the d15b head with my d16 and get any performance increase.
also, i plan on boosting a d series. does the d15b have a stronger bottom end than the d16??
thanks,
-MIKE
BTW: my d16 has over 180,000 thats why i am considering swapping it then boosting. Is the D15B OBD1 anyway??
evo8 is offline   Reply With Quote
Old 01-05-2005, 02:48 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Originally posted by evo8+Jan 5 2005, 01:03 PM--><div class='quotetop'>QUOTE(evo8 @ Jan 5 2005, 01:03 PM)</div><div class='quotemain'>i found this link on HMO for there d15b longblock.
http://www.hmotorsonline.com/shop/sc2000se...page&item=30019[/b]
Yay
Yes, but not the ECU unless you swap the head over.
Some- the cam is hotter, but you would have to run two VTEC solenoids and run the JDM ECU. I would stay with your Z6 head and just swap the cam over if you can.
They're about the same. The D15B revs better though.
thanks,
-MIKE
:P
<!--QuoteBegin-evo8
[/quote]
I think it's OBD1- call and ask. I'm pretty sure it was available as both OBD1 and 2.
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
