car not picking up.
Old 03-01-2005, 10:38 PM   #1
Rep Power: 0 jdm00civicex is off the scale
B20vtec with a 1996 block and 1990 b16a head S1 tranny obd2 setup running p2t ecu with cold air intake stock header and 2.25 exhaust piping with hks muffler. finally got the car to idle at 700 rpms with the fuel psi at 39psi, when u drive it around and floor the accelerator in 1st gear, the car does not pick up it feels as if ur trying to haul ass in 4th gear. still throwing 2 misfire codes. wondering if you guys can help me? thanx
jdm00civicex is offline   Reply With Quote
Old 03-01-2005, 10:50 PM   #2
Rep Power: 14 88bluehf is off the scale
have you replaced your plugs and wires? hows your crank to cam timing? Hows your ingnition timing? new cap and rotor?
*New Ride*
1998 Black DX Hatch
build it....break it....build it....break it...it's a vicious cycle
SOLD:
1988 Honda CR-X Hf
Performance:
1998 D16Y8, 1988 Si Tranny, D16a6 injectors,PM6, 88 accord clutch disc, 91 and up Flywheel and Pressure Plate, Comp Cams 260 Street and Strip CAM, RPM Switch for VTEC(saving up for Hondata ECU) DC Sports 4-1 header, 2.25 Exhaust, High flow Cat, Cold Air intake, b18c5 throttle body
Floss:
JDM Power Window Conversion, Arm rest, EDM door pockets, 91 si gauges, 91 Si taillights, full Si interior swap,and 96 gsr wheels w/kumho ecsta 711's, and projectors.
Suspension:
Koni Sports, Eibach Pro's, Rear Sway
Brakes:
1" Master cylinder, ITR calipers and brackets, 90-91 ex knuckles, redrilled Prelude VTEC rotors up front and 98gsr disc in the rear
Future mods include:
WW RS KIT, S2000 Suzuka blue metallic paint, Power folding mirrors, obd1 hondata, BOOST!!!
88bluehf is offline   Reply With Quote
Old 03-01-2005, 11:03 PM   #3
brand new spark plugs and wires for a b16a, and brand new dizzy with rotor and cap. timing is A ok
Old 03-01-2005, 11:53 PM   #4
Rep Power: 16 nfn15037 is off the scale
Hmm....1.6L ECU on a 2.0L engine maybe?
Friends Don't Let Friends Apex Early
nfn15037 is offline   Reply With Quote
Old 03-02-2005, 12:02 AM   #5
i don't think that should matter
Old 03-02-2005, 12:11 AM   #6
cam timing to crank timing is perfect, how do i set the dizzy timing?
Old 03-02-2005, 12:19 AM   #7
Originally posted by jdm00civicex+Mar 2 2005, 12:02 AM--><div class='quotetop'>QUOTE(jdm00civicex @ Mar 2 2005, 12:02 AM)</div><div class='quotemain'><!--QuoteBegin-nfn15037@Mar 1 2005, 11:53 PM
[/b][/quote]
You don't? A 1.6 to 2.0L is a big jump. Thats .4 litres, nearly 25% more displacement, don't you think it would need just a little more fuel?
Set dizzy timing with a timing light.
Old 03-02-2005, 12:35 AM   #8
Ride:  RX5.7 Civic LS and Teg Ls
Rep Power: 22 civiclxb16 will become famous soon enough
Send a message via AIM to civiclxb16 Send a message via Yahoo to civiclxb16 myspace
the 25% is a big difference. tell you what i will give you my b16 block so you can keep your ecu and give me the b20 block and i will get the right ecu for it
Check Out My Car Club
www.HighRevCustoms.com
and join the forums
this is what happens when you are bored out your mind!!:|
my current baby http://i114.photobucket.com/albums/n.../myspacefc.jpg
civiclxb16 is offline   Reply With Quote
Old 03-02-2005, 12:49 AM   #9
haha dont think so buddy, ive worked hard to earn this this block. thanx for the offer, so wut ecu should i run?
Old 03-02-2005, 12:52 AM   #10
people say p2t 00 si ecu should work for the b20 plus i have a fuel pressure regulator.
Old 03-02-2005, 01:37 PM   #11
What people say and what actually works are two different things.
Old 03-02-2005, 03:59 PM   #12
[/quote]
so which ecu will work with a b20vtec obd2b setup?
Old 03-02-2005, 04:12 PM   #13
Rep Power: 18 b204dr is an unknown quantity at this point
Send a message via AIM to b204dr
gotta convert that shit- obd2b to obd1 gsr ! since obd2b gsr ecus run immobilizers!
friction created heat which creates power=does this apply in the word of automotive
b204dr is offline   Reply With Quote
Forum Jump
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
