Facebook Twitter
Civic EG B16A4 dilemma
This is a discussion on Civic EG B16A4 dilemma in the HYBRID -> EG-EK / DC forum
Yes sir!...
Like Tree1Likes
Old 04-24-2011, 04:18 PM   #51
Yes sir!
vyrus is offline   Reply With Quote
Old 04-24-2011, 04:19 PM   #52
Alright will post back new results in 24 hours. Got hold of new knock sensor aswell. Will replace em all and let you know.
Old 04-24-2011, 04:53 PM   #53
wikedeye's Avatar
Sounds good let me know how it goes.
wikedeye is online now   Reply With Quote
Old 04-24-2011, 05:25 PM   #54
btw my temperature doesn't seem to get to normal levels at times. Even after driving for a kilometre. stays at like 1/4th. What could be it ?
Old 04-24-2011, 05:31 PM   #55
wikedeye's Avatar
Could be a bad thermostat, or it could just be the cold air intake. Mine never gets above about 2/5' s.
Old 04-25-2011, 03:45 AM   #56
Could it be my radiator fan running super fast thus cooling like hell?
Old 04-25-2011, 05:19 AM   #57
wikedeye's Avatar
Doubt it.
Old 04-25-2011, 10:16 AM   #58
God damn my luck! TOday went to get the knock sensor installed, couldn't get it to come off. Guy didnt have proper tool. Will go again tomorrow. Installed the MAP + IAT though , no difference in terms of driving. Still shitty performance.
Old 04-25-2011, 10:19 AM   #59
wikedeye's Avatar
Your main problem with performance is probably the missing o2 sensor.
Old 04-25-2011, 11:20 AM   #60
You think the o2 sensor alone is causing all this issue ?
What if I just get ecu chipped, delete Knock, IAT and MAP from it ? And can I even do that ?
I won't need to go through all the wiring hassle if I can just get it all deleted from the ECU.
Old 04-25-2011, 11:40 AM   #61
wikedeye's Avatar
I am sure it is a problem, but it is probably not the only problem. You can delete the knock, but not the other two. Get a chipped ecu. Did you reset the computer like I said? There could be any number of problems. Your timing could be off, you might have poor compression, etc. I can only help so much since I am on the other side of the world.
Old 04-25-2011, 11:46 AM   #62
yeah I did reset the ecu. Well the MAP issue and IAT issue i will try to resolve now. Knock ill install tomorrow, if it still fucks with me, ill just convert to OBD1 and delete it altogether.
Can you tell me how you converted your engine to OBD1 bro ?
Old 04-25-2011, 11:49 AM   #63
wikedeye's Avatar
Are you still getting the same cel codes?
Old 04-25-2011, 11:55 AM   #64
I was unable to check CEL codes today as I changed my speedometer and for some reason theres no CEL in it at the moment. Will get it sorted together when I go again tomorrow.
Old 04-25-2011, 01:24 PM   #65
wikedeye's Avatar
Put your original harness back in and hook up everything that you can. If your distributor plugs and alternator plugs do not fit the original harness then take the ones from the harness that does fit and solder them onto the original harness. Or get obd1 distributor and alternator. Get your p08 chipped.
I strongly suggest you find someone that has more knowledge about cars than you do to help you out. If you do not know very much then you will likely mess something up and make things worse.
Old 04-25-2011, 01:51 PM   #66
CAFROG's Avatar
Do you still have the vacuum leak form not having that nipple on the TB ran to the charcoal canister? Plug the hole with your finger and see if there is suction
O2 reads and adjust fuel/air ratio.....if its not plug in.....you will run rich and not properly.
CAFROG is offline   Reply With Quote
Old 04-25-2011, 10:02 PM   #67
wikedeye's Avatar
I forgot about this earlier...Are the fuel injectors obd1 or 2? If they are obd1 then nevermind. If they are obd2 then you will need to use the ones from the d15.
Old 04-25-2011, 10:13 PM   #68
CAFROG's Avatar
I believe he stated that the whole longblock was still obd2
Old 04-26-2011, 04:59 AM   #69
Will be doing it soon if this stupid issue doesn't go away.
Old 04-26-2011, 05:01 AM   #70
I believe there is suction still. I have it covered like before using a hose with a screw on the other end.
Also I will still need o2 sensor even after getting the ECU chipped ?
Old 04-26-2011, 05:03 AM   #71
They're OBD1 imo. Coz the wiring is off a d16.
Old 04-26-2011, 05:06 AM   #72
wikedeye's Avatar
If you get a chipped ecu you will not need another o2. Check to see if the plugs for your fuel injectors are modified. It's important because if you use the d15 harness you will have to use obd1 fuel injectors. Have you been able to check the cel codes to see if you have fixed the two sensor problems?
Old 04-27-2011, 07:12 AM   #73
Checked the CELs earlier today. None of them resolved hell i'm getting a new one 04. wtf ?
Old 04-27-2011, 07:15 AM   #74
wikedeye's Avatar
I think it is probably the harness. If you changed the sensors and they still do not work it could be wiring problems.
Old 04-27-2011, 06:27 PM   #75
Im getting the wiring shit sorted now. I just hope the guy can do it this time around. Fuckin waste of my time so far. Ill report back the status bro.
And i wanna thank you for helping me out so far bro, it really means a lot to me . Thanks a ton bro!
WA B16A4 engine wanted silvericerocket Parts: For Sale/Trade/Wanted 0 07-20-2009 12:32 AM
d16y8 wiring harness for b16a4 swap *HELP* xlasianizelx HYBRID -> EG-EK / DC 5 03-07-2008 04:36 PM
Honda : Civic LX 1999 Honda Civic turbo b16a4 engine, many modifications RSS-Bot Auctions 0 11-15-2007 08:23 PM
b16a4?!? 2000Si Members' Lounge 11 07-19-2007 03:51 PM
B16a4(EK4 SiR) Into EX Coupe KyleBrockway HYBRID -> EG-EK / DC 10 03-05-2007 06:44 AM
© 2001-2013 HondaSwap.com
