I am likely coming into possession of a 1986 Yugo GVX. The "sport" model with a 1300cc engine and 5 speed trans. The engine is a piece of junk from sitting outside, and it only made like 54hp to begin with. So my brother wants to see a Honda engine swapped in.
Would the effort of converting the car from cable to a hydraulic transmission setup be worth it? I have an extra hydro trans. Should I use a carbed Honda engine, or how much of the wiring would I need from a fuel injected Civic would I need? The Yugo is carbed. Is there an easy way to figure out the mounting of an engine? Just get the axles straight and make mounts to hold it there? I KNOW custom axles will be needed, but WHO is best to go to for this? I have connections of sorts to get stuff from a junkyard cheap, already own an extra D series engine, trans, exhaust and ECU, engine hoist and I have a welder to fabricate any mounts I need. Any suggestions will at least be considered. |
Ride: dc5,mk4 gti,2nd gen civic,92 accord cp,88 crx hf
theres one of those car in my local area that has a b18b in it so it can be done. but everything will have to be custom made.and i would just keep it cable tranny.
Is there really any advantage to cable trans though? I'm not trying to argue, but I'd rather not buy another trans unless I have to. Or could I convert the hydro trans to cable?
I would need another cable anyway, since the Honda trans sits on the passenger side instead of the driver's side like the Yugo. |
| Tags |
| civic, frankenstein, sohc, swap, transmission, yugo |
| yugo...goes ....gone | Airjockie | Members' Lounge | 5 | 11-20-2008 02:51 PM |
| Project yugo begins | Jdubspeeds | Members' Lounge | 24 | 07-13-2004 04:30 PM |
| Project Yugo Continues! | Jdubspeeds | Members' Lounge | 6 | 04-18-2004 04:28 PM |
| Is Yugo part of Ferrari or what? | Dustin_m | Members' Lounge | 12 | 04-16-2004 12:44 AM |
| D-Series A Yugo | Jdubspeeds | HYBRID -> ED-EF / DA | 8 | 10-28-2003 09:30 PM |
