Ride: 1997 Acura 1.6 EL
I have had my car sitting for 6 days now!
Everythign is done but I cant get the clutch to bleed properly. I ahve done it many different ways, but for some reason, it wont ever come up by itself. Slave is good, Master is good, but I am not able to bleed it. I ahve tried the 2 person thing, I also ran a hose from the bleeder to the master cylinder, no luck.... I need advice pelase help. I cant work without my car! |
Ancient Member
Ride: RHD EG6 jrsc b18c :)
There is air trapped in the slave cylinder, when you bleed it you need 2 people, 1 on the clutch, 1 on the bleeder screw, make sure the res is topped off, then do the normal bleed procedure. (pump up the clutch, hold it to the floor, open the bleeder)
once the fluid stops running out DONT CLOSE THE BLEEDER YET, then have the person at the bleeder actually push the rod back into the slave cylinder until it stops, Then close the bleeder screw. this will get the rest of the air out of the slave cyl. You may have to move the rubber boot back on the tranny so you can see the rod Im talking about. __________________
9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6 doing it myself! 6/1/09 RHD on the road, now time for Body Shop 7/10/09 jackson gsr into rhd+hondata 91 rex ls/vtec b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER! 13.881@102 on street tires Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some reptation, then give 'em a point!---, <-------------------------------- |
| Have to keep bleeding the freaking clutch! | greasemitts | General Tech and Maintenance | 2 | 12-13-2007 02:10 PM |
| B18B1 problems tranny problems... Clutch maybe? | office888 | HYBRID -> ED-EF / DA | 4 | 07-26-2006 09:02 AM |
| Having problems bleeding coolant | 92CHB | General Tech and Maintenance | 1 | 03-18-2006 09:30 PM |
| clutch problems | stuntstere | General Tech and Maintenance | 2 | 07-27-2004 03:47 PM |
| bleeding clutch | jeffsciv23 | General Tech and Maintenance | 6 | 04-09-2004 02:56 PM |
