| | LinkBack | Thread Tools |
| | #1 |
| Ancient Member Join Date: Apr 2004 Location: New York
iTrader: 1 / 100% Ride: RHD EG6 jrsc b18c :)
Rep Power: 30 | Ok, 1993 civic EX B16A sirII LSD tranny Im not gonna get into all the specifics of that we have done motor wise because this car is supposed to be kept under wraps until its final release at the track, either way, we installed clutchmasters stage 5 clutch, pressure plate, flywheel, replaces TO bearing and pilot bearing, stock flywheel. Car ran fine and drove fine for 2 days Problem: when car starts, clutch engaged(up) or disengaged(on floor), car in neutral, horrible grinding noise coming from bellhousing, cannot put car in gear Problem: When car starts in gear and clutch disengaged(pedal on floor) car tries to move as if clutch wasn't being pushed, but its irradicly trying to surge forward (the car) Solutions attempted: Checked fluid level, tranny and hydraulic system Bled clutch system checked for leaks (found none) what the hell should I do next???? there is no way anythign happened to the clutch, its BRAND new, and the motor doesn't have its forced induction on it yet, so its not like any power has been put to the clutch yet. I just don't understand what it could be, maybe its the master cylinder? Either way, from what I can tell its like the clutch won't disengage all the way, (eg not letting the car go into gear when started in neutral, AND when started in 1st gear the car tries to move even with the clutch pushed in. I just don't get it, its almost like when I had a problem with a broken pressure plate a few years ago, but that is technically impossible. Please help me out, send me an e-mail aightbal@nycap.rr.com so I can get this done asap.
__________________ 9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6 doing it myself! 6/1/09 RHD on the road, now time for Body Shop 7/10/09 jackson gsr into rhd+hondata 91 rex ls/vtec b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER! 13.881@102 on street tires Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some reptation, then give 'em a point!---, <-------------------------------- |
| New clutch...Big problem | dcvt16l | General Tech and Maintenance | 4 | 05-20-2004 04:15 PM |
| b16a2/3 swap to 93'coupe, OBD PROBLEM | r.2 | HYBRID -> EG-EK / DC | 13 | 12-04-2003 11:23 AM |
| Problem H22 Swap | Bigjokerdaddyh22 | HYBRID -> BA-BB /CA-CD | 6 | 06-04-2003 07:51 PM |
| H22a Swap Problem Help! | preludejdmh22 | HYBRID -> BA-BB /CA-CD | 4 | 05-03-2003 07:11 PM |
| D15 Sohc Non-vtec Head Swap Problem | auggiereg | HYBRID -> EG-EK / DC | 1 | 02-10-2003 01:30 PM |
