Common Question
Old 02-10-2003, 04:47 PM   #1
Rep Power: 14 creepinRex is off the scale
can someone explain what a port and polish is and does, and also what a 3 angle or whatever is and does.... is it worth it or what???
creepinRex is offline   Reply With Quote
Old 02-10-2003, 05:04 PM   #2
Banned
Rep Power: 0 cbrnascar0329 is off the scale
3 angle valve job definitely but the port and polish of the head i wouldn't..honda heads flow fairly well from the factory so the cost doesn't justify the end result...
cbrnascar0329 is offline   Reply With Quote
Old 02-10-2003, 05:08 PM   #3
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
as a beginer mod... no i would not bother doing either of them ... get all the bolt-ons etc taken care of.... then you will be at a point where you will see the gains and benefits of the PnP, valve job, etc...
МОΛΏΝ ΛΑΒΈ
Old 02-10-2003, 05:11 PM   #4
Rep Power: 14 1_deuceracing is off the scale
Porting is grinding and enlarging the the intake and exhaust opening on your cylinder head to gain optimum air flow and exhaust discharge. Polishing is like the word says, which is basically smoothening the grinded area for better directed air flow. A 3 angle whatever... as you mentioned pertains to the valves. Most stock cylinder head comes with a 3 angle valve job already. It is the angle of the valves itself relevant to the angle on the head for sealing purposes, very critical. When you upgrade a "head", (think car now guys), these are the things you'd want to do, of course there's way more shit to the list I can add, but this should basically answer your questions.
1_deuceracing is offline   Reply With Quote
90' HB DX w/d15, auto \ going to d16 ECU QUESTION lcompeau ECU's, Electronics, and Tuning 2 05-28-2004 10:25 AM
another suspension question 90crxb18 Wheels / Suspension / Tires / Brakes 2 04-28-2004 05:17 PM
QUestion on LS swap Hatchback 95 hybrid HYBRID -> EG-EK / DC 3 08-23-2003 03:24 AM
Common Question... DiGiTal66 HYBRID -> EG-EK / DC 10 05-18-2003 01:55 PM
Basic turbo question zueke Forced Induction 6 10-28-2002 07:04 AM
