Conversion harness
Old 07-12-2004, 08:35 PM   #1
Rep Power: 13 sihatchback_RL is off the scale
Swapping a B20B VTEC into 92 hatch. I wanted to use the chipped P28 i have. The engine harness I'm using is 98 GSR. anybody know i can achieve to use the P28 on this?
1991 Honda CRX Si, JDM B18C GSR Swap, AEBS Manifold, CTR Pistons, DPR ITR Stage 5 Head, Skunk2 stage 2 Cams, Skunk2 cam gears, AEM V2, ANR Header, Greddy E-Manage, ACT 6 puck clutch, AEM fuel rail, Eagle Rods, Type R tranny, Enjo axles, Runs 12.8 ALL MOTOR!
sihatchback_RL is offline   Reply With Quote
Old 07-12-2004, 08:57 PM   #2
Rep Power: 26 projectxspeed is off the scale
Send a message via AIM to projectxspeed Send a message via Yahoo to projectxspeed
Yes
<a href=\'http://home.comcast.net/~projectxspeed/3rdgenteg.htm\' target=\'_blank\'>A Project in Progress</a>
Get your ECU CHIPPED / buy ECU's CHEAP (uberdata, custom ecu maps, and more): <a href=\'http://www.hondaswap.com/forums/index.php?act=Msg&CODE=04&MID=36429 \' target=\'_blank\'>PROJEKTEG</a>
projectxspeed is offline   Reply With Quote
Old 07-12-2004, 08:58 PM   #3
But for a more indepth response the p28 will hook up to the car you will not need the harness.
Old 07-12-2004, 09:04 PM   #4
If the car is wired for vtec its plug and play and if its not you just have run a couple wires to the ecu. As luck would have it running vtec wires is the featured article this month so you're set
Old 07-13-2004, 03:16 PM   #5
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 546 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
92 civics are all pre-wired for VTEC
3rd gen integra engine harnesses fit right into the plugs at the shock towers on 5th gen civics
plug-n-play y0!
МОΛΏΝ ΛΑΒΈ
Old 07-13-2004, 10:43 PM   #6
But i'm using a 98 GSR engine harness, isn't that OBD2? do i have to get an adapter?
Old 07-14-2004, 02:33 AM   #7
Rep Power: 16 sleepercivic is an unknown quantity at this point
use your stock harness, extend wires as needed, and add vtec wires to shock tower
10/12/07--94 ex for Sale Black/Black pm for details/ Honda-tech.com egsleepercivic
sleepercivic is offline   Reply With Quote
Old 07-14-2004, 02:37 AM   #8
B happy
92b16vx's Avatar
Ride:  dohc 95 egg
Rep Power: 186 92b16vx has a reputation beyond repute
92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute92b16vx has a reputation beyond repute
Use the GSR harness, it plugs right into your Civics canon plugs, no adaptre or anything. Have the P28 chipped to run that motor, and plug it right into your ECU hanress, pretty simple. No need to use or modify your stock harness.
95 CX|B16A2
XBL | binary xj0hnx | Halo 3
Old 07-14-2004, 03:24 PM   #9
E_SolSi's Avatar
Originally posted by 92b16vx+Jul 14 2004, 02:37 AM--><div class='quotetop'>QUOTE(92b16vx @ Jul 14 2004, 02:37 AM)</div><div class='quotemain'> <!--QuoteBegin-sihatchback_RL@Jul 14 2004, 03:43 AM
Use the GSR harness, it plugs right into your Civics canon plugs, no adaptre or anything. Have the P28 chipped to run that motor, and plug it right into your ECU hanress, pretty simple. No need to use or modify your stock harness. [/b][/quote]
МОΛΏΝ ΛΑΒΈ
