I have searched on this topic extensively but all I can find about OBD1-->OBD2 is stuff about selling the jumper harnesses or putting newer motor in older chassis. I have the exact opposite problem...I want to convert to OBD2 so I can pass emissions testing.
Currently I have a 1995 JDM H22A in my 4th gen Accord. I bought an EK a few months ago and I want to move the motor over...however my only options are to find someplace outside of the 'emissions testing region' to register my car or actually make it legal. I am somewhat confused though. I plan on going further than just putting the motor in the car (read that as turbo) so I eventually will be running the AEM EMS. I know that wont pass emissions but as long as I had the car correctly wired I could always plop in an OBD2 ecu when testing came up right? As long as I have the OBD2 version of the EMS everything seems as if it would be ok. Basically I just need to know which sensors need added/changed to be able to use the ODB2 ECU and not fail. I am aware of the sensor in the gas tank, the secondary 02, the distributor...but past that I am stuck. Also, would an OBD2 GSR ECU be able to pass the emissions testing with the H22A? I know it would not be an optimal choice, but again I am planning on running the AEM EMS so I don't really want to buy the very expensive OBD2 H22A4 ecu (w/o immobilzer) if I don't have to (but I will if it comes down to it). Is this even possible? Should I just sell my H22A and get an OBD2 motor to begin with? Thanks in advance. |
#3 | |
I live in Oregon. All they do for OBD2 test is hook up to the data port and read if there are any errors. I am hoping that I can figure out what I need to add to my motor so that it can pass. |
my avatar is better.
well i had a b18c1 in my 95 coupe and i passed fine. I guess because in md all they did is hook up a hose and check my gas pressure. Sorry i cant help to0 much but HS helped me out just give it a day or so you will have the answers u need or be on the right track.
#5 | |
Thanks. |
#6 | |
Been down so long...
Ride: '98 Civic w/ Turbo H22A
#7 |
hmm.. my last post didnt go through. I am in OR also. I have a 98 Civic with an H22A. How did you get this done? I am in dire need of figuring this one out.
| H22AdelSol's H22A swap guide. | H22AdelSol | HYBRID -> BA-BB /CA-CD | 14 | 08-04-2008 09:53 PM |
| Jdm B16a Sir Ii Wont Pass Smog. Anyone In Bay Area | Akirazian | Members' Lounge | 16 | 09-21-2007 01:25 PM |
| CRX won't pass smog | integrator | General Tech and Maintenance | 5 | 03-10-2004 09:50 PM |
| jdm B16 smog test | crxloon | HYBRID -> ED-EF / DA | 11 | 09-21-2003 03:54 AM |
| smog test | krossoverr33 | General Tech and Maintenance | 6 | 08-17-2003 10:27 PM |
