CRV B20 vtec into 97 civic swap complete!!!
Old 07-22-2003, 04:35 PM   #1
Rep Power: 18 khai_tuan_nguyen is off the scale
I just completed the B20 vtec swap into my 1997 coupe civic hx. Here are the problems i am having. It starts and runs fineeeeeeeee. However whenever i have cold starts (park the car overnight, wake up to go to work) the car turns over cranks for awhile and then starts. I then have to let it warm up for like a minute or 2 or if i drive the revs will drop and it will choke and die. If i let it warm up it is fine. However when i am at work for 9 hours and try to start it it turns over and the rpm goes up normal and slowly drops down to under 1000 and then dies. I turn it again and it does the same thing. The only way to start it like this is to start it with a little pedal down to keep the revs up but even then it cuts in and out, until it warms up then it is fine. this is always the same pattern, in the morning it cranks for a while but starts idles fine. Then later in the day it cranks and dies. LAstly the engine gets damn hot, like i could cook and egg on the headers after a few minutes of the engine being on. IS this normal. Compression is 12:1. Someone said it has to build compression or something. the thermostat and radiator fan is working fine. One other thing when i first crank the car and it idles fine the idle is at like 1100, which is fine, but when it warms up and i drive the idle goes to like 1500. The enigine is being broken in and i've only put about 120 miles on it. Thanks for the help in advance.
<a href=\'http://www.hondaswap.com/forums/index.php?act=module&module=gallery &cmd=user&user=25607&op=view_album& album=107\' target=\'_blank\'>PICTURES: Type R Stuff/ B-Series Parts for Sale</a>
khai_tuan_nguyen is offline   Reply With Quote
Old 07-22-2003, 04:38 PM   #2
Oh i am running 250 cc injectors going with OB2 setup, and GSR ECU if that helps. Any questions let me know. I can get a set of RC 310 cc injectors for dirtcheap ($150). Should i upgrade to these? Any other suggestions for making my motor reliable yet fast. It is bored to 2.2L and i use Arias pistons. Injen intake and Greddy Evo full exhaust.
Old 07-22-2003, 04:55 PM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 288 Calesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud ofCalesta has much to be proud of
Build compression? No, that's wrong.
What kind of bore are you running for 2.2L? If you're bored to 2.2L, your pistons would be rubbing against each other.
I wouldn't upgrade to 310cc injectors unless you can tune for them. Have you tuned the engine at all? There isn't really a stock program that will run a B20/VTEC setup that well.
Old 07-22-2003, 05:17 PM   #4
Rep Power: 16 dcsports413 is off the scale
Send a message via AIM to dcsports413
you said it starts fineeeeee....? no, i wouldn't say it starts fine with all of the problems you just described. Have you do a tune-up yet with the new swap (new spark plugs, wires, etc, etc, etc....)
The header being hot is normal.
Bulid compression???
Dave
Philippians 4:13
dcsports413 is offline   Reply With Quote
Old 07-22-2003, 06:44 PM   #5
When i said it starts normal i mean in the morning. It cranks a few times and turns over and idles. Build compression as in it has to crank a few times to build compression for the 12:1. Maybe it is not 2.2 then. i don't know
Old 07-22-2003, 06:56 PM   #6
If you can, list your complete list of parts used to place this motor together and what elements you are running with, which ecu, etc...
Milan
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Old 07-22-2003, 06:58 PM   #7
Rep Power: 29 rudeludenotmeanthough is off the scale
how do you not know???. did you build it or a shop??
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (94RedSiGal @ Dec 2 2003 @ 12:27 AM)</td></tr><tr><td id=\'QUOTE\'>Having a ClubSi, Honda-Tech or HondaSwap sticker on them would just scream &quot;Steal Me Now! I'm a special car!&quot; to thieves.</td></tr></table><div class=\'signature\'>
rudeludenotmeanthough is offline   Reply With Quote
Old 07-22-2003, 07:05 PM   #8
I don't know, because I had a friend who knows the owner of a shop build it (redline performance in oregon) I just got it finished like 2 days ago and have not received all the specs on it. It was bored over a few times at the machine shop to clean it up a bit. The parts. Its a 99 si head and a b20b block with arias pistons. All parts on the head are off a 2000 civic si, except the distributor, that is off a 94+ gsr. New oil pump, new injectors, new belts (all oem). I am running DC ceramic 4-1 header, greddy cat back exhaust (2.5 piping) , 2 o2 sensors, knock sensor, no power steering, no ac, cheap catalytic converter 2.5 piping. Anything else. Anyone know why the engine would be idling at about 1100 and when i drive it or it warms up it actually idles at 1500. Or why it would start the way it would. The timing was triple checked and it correct. Any other questions? Thanks for all the help guys. Like i said though once i can keep iot idling i don't have to do anything it runs normal and idles fine. The problem is getting it to idle at start up. Even once i get it to idle normal, i can shut it off and start it right back up and it starts on the first crank. I hope this description is helping. thanks
Old 07-22-2003, 07:11 PM   #9
the people who put my engine are away for a week that is why i need the help. Any suggestions
Old 07-22-2003, 07:12 PM   #10
By the way what are some issues that i could run into with my setup. First and foremost to me is reliability. Anyone know what is a safe rev limit or how bad it really is to be using a GSR ecu for the engine management?
Old 07-22-2003, 07:36 PM   #11
bump
Old 07-22-2003, 07:47 PM   #12
Ride:  DC2 ITR and DC4 LS
Rep Power: 19 Gen2Teg is off the scale
Send a message via AIM to Gen2Teg Send a message via Yahoo to Gen2Teg
just wait a bit, that happend to my friends car when he dropped in his motor too. I forgot what the problem was, I think it was the IAC valve or something along the lines of that. It was either that or something that just went away with time, don't know how though.
Gen2Teg is offline   Reply With Quote
Old 07-22-2003, 08:32 PM   #13
bump
Old 07-22-2003, 10:07 PM   #14
Calesta's Avatar
Ride:  2003 S2000
Stop bumping every hour. NOW.
Old 07-23-2003, 12:28 PM   #15
any other suggestions
Old 07-24-2003, 11:22 AM   #16
nothing?
Old 07-24-2003, 11:30 AM   #17
Ride:  '92 Civic CX
Rep Power: 39 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
make sure you check your idle... http://www.hondaswap.com/~pills/idlefix.html go there
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
Old 07-24-2003, 01:22 PM   #18
Ok since my last thread was closed, eventhough i was asking new questions. I was told to write them in here. So here is my cut and paste copy of my other thread. Sorry modys for giving you extra work.
I just finished the B20b swap into my 1997 civic hx. Here are some questions i have for you guys. Basically its a B20B block, remachined with Arias pistons and a 2000 si head. All internals on block are stock except the pistons. Everything on the head is also stock (distrubitor, alternator etc). We did put new belts on, spark plugs etc. I am running 4-1 DC LS ceramic headers and greddy evo exhaust with a universal catalytic converter (2.5 inch piping all the way) MY ECU is off of a GSR and my injectors are 250cc. I am running on OBD2 with both O2 sensors and knock sensor etc.
1) What are some of the problems that might happen to me with my setup. For example not enough fuel, engine cutting off, reliability etc.
2) Cars usually idle high when you first start them and as it warms up the idle goes down. Mine idles at about 1100 and as it warms up idles about 1500. anyone know why? IS this normal?
3) Is it normal for a car to idle that high?
4) Also it is hard to find the correct timing for the car to idle high enough to start up and have enough power? Any suggestions how much i should idle (rpms and timiong) it at.
Old 07-25-2003, 11:18 AM   #19
Thumbs up
I tried messing with the timing and that is the only way i can get it to start, after it starts once it can be shut off and started again easily, but after it's been sitting for awhile (3 hours or so) it cranks turns over and dies. Could it be the timing? the starter? The distributor( I am using a GSR distributor)? The ecu (maybe the fuel/air management by the GSR ecu is not good enough for a crv block ). Not enough spark? Does anyone know if it is safe for a car to idle 1500 or 2000 or why a car starts at 1000 and as it warms up goes up? No matter what i do with the timing once i can get it to start it idles at 1000, until i drive then it idles depending where i put the timing.
Thanks
Old 07-28-2003, 11:29 AM   #20
My last attempt at help... PLEASE !!!!!!!!!!!!!!!!!!!!!!!!!!! j/k any help is appreciated.
Old 07-28-2003, 04:55 PM   #21
Anyone know where to refer me to find out this info?
Old 04-03-2009, 12:56 AM   #22
Greenhorn
Ride:  1995 Honda Civic DX :( and a 91 DX :(
Rep Power: 0 markalan is on a distinguished road
No I haven't a clue man. Sorry could not help. staying alive
markalan is offline   Reply With Quote
Old 04-03-2009, 01:28 AM   #23
Rep Power: 2 nicky is on a distinguished road
Default Why?
This by far has been the oldest back from the dead thread ever.
Dude almost 6yrs later. WHY?
nicky is offline   Reply With Quote
Old 09-24-2009, 03:39 AM   #24
Rep Power: 0 cvc_98 is infamous around these parts
Hahah thats cold. But ill put it into it to and give it a guess. . . fuel pump. So OP was your problem resolved by the way or the car was sold a long time ago haha.
cvc_98 is offline   Reply With Quote
SOHC vtec swap, and EW4 swaps, 86 CRS si reckedracing Parts: For Sale/Trade/Wanted 5 08-25-2008 05:47 PM
6th gen Civic Basic swap overview pissedoffsol Swap Articles 0 01-12-2004 02:14 AM
Vtec swap into civic dx brettster96 HYBRID -> EG-EK / DC 1 11-15-2003 12:28 AM
B18a non vtec swap into 4g civic H/b Dx streetinvader HYBRID -> EG-EK / DC 5 10-18-2002 08:23 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
