D-series manual motor to auto tranny???
Old 07-08-2005, 08:35 PM   #1
Rep Power: 16 Teambypass is off the scale
Hi guys, I havent done this before but I think its should work. let me know what you think and have anyone done it. I have another D-series motor complet with everything laying around. There is a 96 coupe EX AUTO, the motor is bad, but the tranny is good. the car is in good condition, no rust, only 90k and the old man want $1300 for it. I figure, if I could just put my old motor, 60K out of a 96 hatch dx, into that then I would have a realiable car to drive for the winter and save on gas and park my baby in the garage. To my understanding, since the motor from the coupe is, I will swapp in my motor from the manual car into the auto car, and to make it work, I will just remove the flywheel from the motor and this will bolt the manual motor directly into the auto tranny right? correct me If I am wrong or if there is anything that I need in order to make this work. thanks in advance.
I am not in2RACING, RACING is Me!
96 cx hb with 98 JDM GSR, IB probe 12:3:1 7.1cc pistons, IB ultralite rods, skunk2 stage2 camshafts, valves, springs, retainers, cam gears, skun2 intake manifold, Eldelbrock 65mm throttle body, 4-2-1 DC, Quaife LSD, Findaza flywheel, Fsudo cat back with OBX high flow cat, a valve job with light port and polish, hodata s200, walbro 190 fuel pump, RC370cc injectors, and AEM fuel rail & regulator, NGK spark plug wire.
STOCK BEST ET: 14.7 AT 95.3 mph.
WITH MODS BEST ET: 14.2 AT 99.8 MPH
Teambypass is offline   Reply With Quote
Old 07-08-2005, 09:47 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
All you should need is the parts from the auto engine/tranny combo to bolt the manual engine on there- remove the flywheel and replace it with the flex plate so that it can bolt onto the torque converter.
Old 07-09-2005, 12:21 AM   #3
Go fast, Go Cheap
Ride:  Hybrid POWER!
Rep Power: 24 jimboburgess will become famous soon enoughjimboburgess will become famous soon enough
Send a message via AIM to jimboburgess Send a message via Yahoo to jimboburgess myspace
yeah
es ist gut
Resurrected Sol
http://hondaswap.com/auto-multi-medi...ted-sol-60210/
2003 Civic Hybrid (I'm a grown-up now)
www.myspace.com/burdenelectronica
jimboburgess is offline   Reply With Quote
Old 07-11-2005, 09:43 PM   #4
thanks for the comfirmation
Old 07-11-2005, 09:45 PM   #5
well, the manual intake manifolds are different than the auto's.
sensor placement or something like that.
90 Integra Sedan
B20V 225 / 153
Old 07-11-2005, 09:46 PM   #6
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
Also, make sure you use the auto flywheel/flexplate bolts instead of the manual ones. They have slightly diffrent lengths, so you need to use the auto ones if your putting an auto flex plate on there, manual if your putting a clutch and flywheel on the engine.
Collin
Material Science and Engineering
Michigan Technological University
Old 07-13-2005, 01:28 PM   #7
Rep Power: 11 2naboy is off the scale
also, the driver side engine mount is different at least in the 92-95. since the engine is from a manual, you will need to use the mount of that engine.
2naboy is offline   Reply With Quote
