d15 to d16 manifold question
Old 08-05-2008, 09:11 PM   #1
Rep Power: 0 Shawk is on a distinguished road
Default d15 to d16 manifold question
I swapped from a d15 non vtec to a d16 vtec, the manifold went from 4-1-1 to 4-2-1 but I'm using the 4-1 manifold right now because I don't have a down pipe for the 4-2.
How much does this effect my performance? the d16 is running at about 160-170 compression (108k on d16,) and it just seems no better than the d15 non vtec I just had in.. and driving it on the highway I could not pass 170 km/h with my foot completely to the floor for a good 5 minutes.. I could get to 220+ km/h with the d15... and it had 350,000 clicks on it and horrible compression.
I'm getting a Header soon but I was just curious if this is my main problem right now performance wise. Thanks.. sorry if covered already.
Shawk is offline   Reply With Quote
Old 08-06-2008, 05:29 PM   #2
Rep Power: 0 rocknwood is on a distinguished road
Hey, here is my experience on this one: '93 Civic DX hatch (D15B7) with a '92 Si (D16Z6) ex. manifold made a noticeable difference. I also had the entire Si exhaust on this DX with a cone filter on the other side. The DX and Si hatchs have about everything lining up identical, so you can swap away with better flowing parts. If you were to lay all these exhaust parts side by side, all openings on the Si are a larger diameter. In my opinion, just buy the header, and put it on. Then get ready to experiment. I have built a couple '92 Si's that will fly with that D16Z6, and still get 40 mpg on the highway.
rocknwood is offline   Reply With Quote
Old 08-26-2008, 05:46 PM   #3
new to Hondas not to cars
Ride:  1995 EG8 D15B swapped
Rep Power: 0 meanmugen is on a distinguished road
what ecu are you running? did you wire for vtec?
Nevermind
Last edited by meanmugen; 08-26-2008 at 06:05 PM. Reason: Cause I did read that it was an ancient thread
meanmugen is offline   Reply With Quote
H22 in a EG intake manifold question hapa HYBRID -> EG-EK / DC 2 07-29-2008 02:30 PM
can you- manifold question kevinbout Civic and del Sol - EG and EK 35 04-26-2008 07:41 PM
manifold question ripperbone Engine Building 1 04-18-2006 01:27 PM
manifold question 93vicb16a2 Forced Induction 2 03-18-2006 10:38 PM
manifold question boost_fed_ef Forced Induction 0 07-23-2005 11:11 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
