does anyone know where to get a d15b, and if there is any aftermarket at all for it? i had been thinking about the z6 for a while, but it seems like the d15b would be just as good, if not 5hp better. any info on this motor would rock. bolt in? ecu? shit like that. *reminder* ive got a 92 lx sedan ($200 y0!). also, opinions about d15b vs d16z6 vs d16y8
Castles made of sand melt into the sea...eventually *crappy 92 lx* still trying to save for the z6 swap. yeah, im that broke. |
#2 | |
Member of the 20 nut club
go to hmotorsonline they have them over there .... personally i think its a waste .... but knock yourself out
#5 | |
#6 |
ziggity 6 it is, then. i just wanted reassurance, cuz theres one local for 450, and i didnt want to get it if the d15b would be better. if im right, thats a jdm motor, isnt it (d15b)? the main reason i thought z6 was because of the decent aftermarket support. (turbo, exhaust, etc.) i think after i buy it, im just gonna tear the shit out of it - cleaning, replacing gaskets and whatnot. put it in later. but i know how my patience is, so im not sure.
#8 | |
#9 | |
B happy
Ride: dohc 95 egg
Check out yourl local strip yards, you may get lucky. It isn't worth the shipping cost for the extra 5hp that the D15B MIGHT have (maybe it was abused). You should be able to find a complete swap for $300-$500, if not just get the motor/ECU and bolt it to your tranny for now.
95 CX|B16A2 |
#10 |
i can get you a D15B for 400 plus shipping i am in chicago and i will ship anywhere you are for 150
Well it seems that no matter how hard i try i just get screwed in the end...but at least i have my honda to keep me company... |
#11 |
shit! im in iowa, and i could just come get the fucker! let me get my shit together with this moving business, and ill get ahold of you. if you sell it before, just pm me and let me know.
unless...someones got a z6 cheap. lol
#12 |
hi, i have a d15b2 for you i'm in VA so i'm not sure of shippin costs but i'll sell it to you for $150 plus shipping (i'll get info of shipping costs for you if you want this motor). you will get the motor, trany, ecu, axles, basically full swap. the clutch is slipping and goin bad but i have a brand new clutch kit, with clutch pressure plate, alignment tool, and release bearing still in box brand new never used, that i will ship along with the motor. the only thing wrong with the motor is one of the rings is fucked up therefore eating oil (3 quarts last about a month), but that can be fixed at a nearby shop fairly cheap. reason i'm getting rid of it this cheap is because i have a JDM b18c5 motor swap and this d15b2 has been sitting in garage for about a month now and i have no use for it, if shipping is expensive i will drop swap price to $125.... if you are seriously interested pm me or email me
1988 Honda CRX JDM B18C5 (ITR) Motor JDM B16A1 (OBD0) Vtec Tranny 17" Tenzo RS-5 White Rims wrapped with Kuhmo Supra Ecsta 712's Power Stop Cross Drilled/Slotted rotors Skunk 2 coilovers (3" drop) Tokiko Gas Shocks High Flow cat with custom 2.5" exhaust with greddy SP muffler AEM Fuel Rail 440cc injectors Crower stage II cams with valves and springs cmaster Stage II Clutch and fidanza flywheel (aprox 6 to 7.5 lbs) GSR fuel pump COmpletely gutted with exception of guage cluster Spoon ECU Program. Street tires, 102 degrees F, 80% humidity ran 13.6 @ 117.36 MPH... i figure with slicks on a cold non humid day i can hit high 12's hopefully |
#13 |
Google search Noyan USA. This place in Manassas, VA caries JDM D15B's with transmissions for $300. I don't know if it really is a good deal because their warranty on miscelaneous parts it non-existent, but there is a 6 month unlimited mile warranty on the internals of the engine.
How does the D15B compare to the Z6 as far as bore size, compression, and replacement parts like timing belt and head gasket? |
#14 |
Noyan USA is a good place for motors and realiable, that's where i got my b18c5 and where my friend got his h22 for integra in the last 4 months nothing has ever gone wrong with him motor, no codes, nothing same goes for mine.... here is a comparison between the d15b and d15z6 motors
D15Z6: Engine Model D15Z6 SOHC VTEC Engine Displacement 1493cc (1.5l) Engine Power 115 BHP Compression Ratio 9.6:1 Bore 75mm Stroke 84.5mm Top Speed 119 mph or the newer z6 in the 92-95 civics and 93- 95 Del Sol D16Z6: Engine Model D16Z6 SOHC VTEC Engine Displacement 1590cc (1.6l) Engine Power 125 BHP Compression Ratio 9.2:1 Top Speed 119 mph D15B: Engine Model D15B2 SOHC Engine Displacement 1493cc (1.5l) Engine Power 92 BHP Bore 75mm Stroke 84.5mm Compression Ratio 9.2:1 Top Speed 119 mph as far as replacement parts the d16 and d15 are 2 diff displacements the gaskets won't fit, not sure about timing belt and sorry that i couldn't get info on bore size for the newer z6 but they should be relatively the same...
#16 |
i believe that's actually the 1.6l ZC motor which is nothing more than the JDM version of the non-vtec LS motor but more restrictive (hense the 10 hp loss)
#18 |
i know what the number's in honda motor codes stand for, i just wasn't sure about what you are asking, found the motor you are asking about D15 w/ vtec, there are no d15"B" with vtec, the only d15 motors with vtec are the d15z1 and the d15z which can be found in the USDM 96+ Civic HX (d15z) and the 92-95 Civic VX (d15z1)
the specs on these motors are as follows: d15z1: 1493cc SOHC VTEC-E 9.3:1 Compression ratio 92hp @ 5500 RPM 97 ft lbs tq @ 4500 RPM redline @ 7000 bore 75mm stroke 84.5mm d15z: 1493cc SOHC VTEC-E 9.4:1 compression ratio 115 hp @ 6200 RPM 104 ft lbs tq @ 5400 RPM (not 4500) redline @ 7100 RPM bore 75mm stroke 84.5mm JDM honda never produced a d15 with vtec after the 88-89 jdm CRX (d15b) they went to the b16 series motor in all civics....
#19 | |
B happy
Ride: dohc 95 egg
Have a look, and help stop the spread of misinformation.
95 CX|B16A2 |
#21 | |
92 hatch, b18c block b16 head rsr GT-II exhaust, skunk2 valvetrain. skunk2 manifold <span style=\'font-size:14pt;line-height:100%\'><span style=\'color:red\'> Michael Moore...You've just been pwnd'</span></span> |
#22 |
thanks guys. i want the z6. easier to find parts, and aftermarket kicks ass. i thought about how hard the d15b would be to find parts for, and its not worth it. except that i could go jdm and fuckin mean it when i have to have a gasket imported!
but i figure the z6 would be a snap. btw, does anyone know what ecu i have? its not in reference, that i could find. 92 lx sedan (d15b7) thanks.
#25 |
just use the USDM spec parts they should all work the motors are the same except one is from japan.....
