Facebook Twitter
D16A6 into 6th Gen? Crank Sensor A Problem??
This is a discussion on D16A6 into 6th Gen? Crank Sensor A Problem?? in the HYBRID -> EG-EK / DC forum
So I have a D16A6 short block that I was hoping to toss into my EK for a daily driver, but I'm concerned about the crank sensor. Is this swap even possible? Where does the crank sensor mount and can I transfer it to the ...
Old 08-09-2010, 10:07 AM   #1
rfrumusa01's Avatar
Default D16A6 into 6th Gen? Crank Sensor A Problem??
So I have a D16A6 short block that I was hoping to toss into my EK for a daily driver, but I'm concerned about the crank sensor. Is this swap even possible? Where does the crank sensor mount and can I transfer it to the A6?
rfrumusa01 is offline   Reply With Quote
Old 08-09-2010, 11:29 PM   #2
tabKola's Avatar
It mounts on the Y5/7/8 oil pump, so you would have to swap over the pump, but then you would have 2 dipstick holes.
tabKola is offline   Reply With Quote
Old 08-10-2010, 03:39 PM   #3
d-mon's Avatar
just get an obd2/1 conversion harness and a p06 ecu.
keep your y8 intake and exhaust manifolds.
d-mon is offline   Reply With Quote
Old 08-11-2010, 09:17 PM   #4
D16SiHatch's Avatar
it's a ckf sensor on the oil pump. easy to bypass
.:FFS TechNet:. » ECU & WIRING How-To Articles » CKF Bypass Trick
D16SiHatch is offline   Reply With Quote
Old 08-15-2010, 09:15 AM   #5
suspendedHatch's Avatar
Search for FFsquad and how to do the CKF bypass trick.
suspendedHatch is offline   Reply With Quote
FS: D16a6 Lightweight Crank Pulley 89' Project Civic Parts: For Sale/Trade/Wanted 1 05-10-2009 02:37 PM
Crank sensor problem Wildbill64 Civic - EP, FA, FG 2 12-02-2008 03:28 PM
1990 CRX Si D16A6 Head Sensor 89Si Civic and CRX - EF 2 02-18-2008 09:35 AM
ls crank sensor? honda801 ECU's, Electronics, and Tuning 2 09-20-2007 05:21 PM
Crank Sensor Domi31 General Tech and Maintenance 7 04-14-2006 08:53 PM
© 2001-2013 HondaSwap.com
