D16Y8 into a 94 Civic EX with a D16Z6
Old 12-03-2007, 06:24 PM   #1
Cush00 is on a distinguished road
Default D16Y8 into a 94 Civic EX with a D16Z6
Ok, I'm definately a noob when it comes to hondas. I have biult chevys, fords, and even VW, but this is my first honda swap. My girlfriends 94 Civic Ex, took a dump on her and I have a line on a 96 Civic with a D16Y8 in it. Is there anything I should look out for during the swap? Is this an okay swap? Should I try to find something different? I have searched and from what I found it shoud basically just bolt in, right? Please give me any help you can as I am new to this and could definetaly use it.
Thanks
Clayton
Cush00 is offline   Reply With Quote
Old 12-03-2007, 06:37 PM   #2
Ride:  06 gmc 2500 Turbo Ls Civic
igotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud ofigotnothin has much to be proud of
the engine will bolt right up, but the 94 engine is obd1 and the new engine is obd2. Not that big of a issue, just you will need an obd1 dizy, altinator, and fuel injectors. Might help to just swap thintake many from the old engine on to the new one, but im not sure which one flows better. The new engine will havea few sensors you wont have a spot for on your harness, but thats ok, cause the ecu wont be looking for them. Its much easier to put an obd2 in and obd1 chasie, than the other way around
Boost Big or Boost Small. Just make sure you remember the Boost.
igotnothin is offline   Reply With Quote
Old 12-03-2007, 06:50 PM   #3
Thank you very much, I will be starting this tomarrow then...
Old 12-03-2007, 10:23 PM   #4
Another quick question. The 96 has a manual tranny and my 94 has an auto. Would it be worth it to convert to manual? I would rather have the manual.
Old 12-04-2007, 10:22 AM   #5
90_EF_Hatch's Avatar
Ride:  93 BMW 325i sedan, 93 Teggy four door
90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of90_EF_Hatch has much to be proud of
myspace
Manual is always better in my opinion ... and if you have the tranny for it why not?
90_EF_Hatch is offline   Reply With Quote
Old 12-04-2007, 10:50 AM   #6
dtob's Avatar
dtob is an unknown quantity at this point
If you are using the ecu out of th 96 it won't run the auto tranny. You'll either have to use the manual tranny and convert or get yourself an auto ecu to run the vtec.
dtob is offline   Reply With Quote
Old 12-04-2007, 10:58 AM   #7
myspace
oh yeeeaaahh ... i forgot about that little tid bit.
Old 12-04-2007, 04:18 PM   #8
um if you are going to convert to a many sell the car and get a manual. its a lot of work, not really hard or anything, but alot of pain in the ass for little result. Its cheaper to sell the auto and buy a manual, but if i were you id just get an auto ecu and call it good
Old 12-04-2007, 05:15 PM   #9
Dasfinc will become famous soon enough
D16Y8 Intake Manifold flows MUCH MUCH better than anything else, however the automatic and manual Y8 manifolds are not interchangable.
Dasfinc is offline   Reply With Quote
Old 12-04-2007, 07:16 PM   #10
So I can't use the 94 ecu on the 96? So the D16Z6 auto tranny won't bolt up to the D16Y8 with the manaul intake?
Old 12-04-2007, 10:49 PM   #11
dtob's Avatar
Why don't you just find an original motor for the car? It will probably be easier to swap, you wont have to do any re-wiring etc. Then sell that car and buy one with a manual and vtec.
Old 12-04-2007, 11:50 PM   #12
you can youse the 94 ecu that is fine. and the intake many wont effect the trany bolting up. He was just saying that the intake manifold on the engine is diftent for the manual and the automatic. I didnt know that, looked like it would be fine for my bros car, which was an auto, but i never bolted it on so idk.
Old 12-05-2007, 07:43 AM   #13
The 94 already has vtec.
Old 12-05-2007, 10:44 AM   #14
dtob's Avatar
Ok well forget the vtec part then.... wtf is the difference? You want vtec and manual whether you have a vtec engine already or not.
Old 12-12-2007, 04:42 AM   #15
you get the BRAKE
LS_VTEC's Avatar
Ride:  all motor eg6
LS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to beholdLS_VTEC is a splendid one to behold
Send a message via AIM to LS_VTEC
just swap bottom ends, keep your z6 head (if the valvetrain is not damaged), so no wiring is needed. keep it auto, converting to manual will be a pain, ive done it. a lot of time at the junkyard salvaging parts, its not fun.
LS_VTEC is offline   Reply With Quote
D16 Vitara pistons D16Z6 D16Y8 75mm Civic CRX Turbo YCP RSS-Bot Auctions 0 11-21-2007 05:13 PM
1990 Civic DX HB /w D16Y8 NA - Power Swap Jon_S13EF HYBRID -> ED-EF / DA 16 05-24-2006 07:43 PM
WTT/ 94 Civic Vx Hatch D16z6 in Kansas City MO Unit02VXHatch Vehicles: For Sale/Trade/Wanted 5 03-01-2006 06:34 PM
F/S A Bigs list of d16z6 And 92-95 Civic parts Boosted4dr Parts: For Sale/Trade/Wanted 31 04-10-2005 10:03 PM
Need some help with Trim Names YangpaNemsay General Tech and Maintenance 7 08-31-2003 03:43 PM
