d16y8 swap into 92 dx.. need help
Old 04-01-2004, 07:26 PM   #1
Rep Power: 14 importstyle is off the scale
Send a message via AIM to importstyle
I dont wany any opionions about me doing this swap only anwsers please...
i have a y8 swap and i can get no clear anwsers about this swap, i am going to use my stock dizzy, and i have an ecu from a 94 si manual, and i am ready to do this swap.... i just hear about all this crap about you dont want to go from obd1 to obd2... i just need some clear anwsers about what i need to do please... i have search and searched and found no anwsers.........
thanks Chase
importstyle is offline   Reply With Quote
Old 04-02-2004, 09:04 AM   #2
no help?
Old 04-02-2004, 10:04 PM   #3
Rep Power: 14 BseriesKllR is off the scale
alright ill help a guy out....well if your gonna use the p28 ecu and your dx dizzy then just convert the engine to obd1....not a bad swap you will be pleased i love my sohc. I think you will have to swap injectors and some stuff to make obd1 just let me know if you need help? or if you need some d-series help check out D-Series.Org im sure all the answers lye there.
89 CRX HF..d16z6,i,h,e,cam,9.9:1 compression<--weak.
Gsr brakes, Rear Discs, Lowered, Hx wheels.
14.24@95
2.20 60'
soon 60 shot for the z6.
Building high compression A6 block.
BseriesKllR is offline   Reply With Quote
Old 04-02-2004, 11:02 PM   #4
yeah man i realyl need your help........ ill check out, well no i am a member at d-series.org.......... but yeah i got stuff going on tonight but ill talk to you about it tommorow
Old 04-02-2004, 11:57 PM   #5
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
p28 and 3 plug conversions for the dizzy, alt, and injectors, and its plug and play if you use the z6 harness.
Old 04-03-2004, 05:57 AM   #6
Member of the 20 nut club
E_SolSi's Avatar
Rep Power: 541 E_SolSi has a reputation beyond repute
E_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond reputeE_SolSi has a reputation beyond repute
МОΛΏΝ ΛΑΒΈ
Old 04-03-2004, 05:42 PM   #7
so basically you are saying dont try and do it with my harness?????
Old 04-03-2004, 05:43 PM   #8
what if i use the alt injectors and dizzy from my dx?
Old 04-05-2004, 12:41 AM   #9
Rep Power: 12 MarkN929RR is off the scale
Send a message via AIM to MarkN929RR
Angry
I just did this swap, ok here is all my knowledge.
a: if you going to use your stock DX harness your going to need to change your injector plugs, alternator plug, and dizzy plug. (its a pain in the ass to do) I dont recomend it.
b: p28 is great!
c: dont use your dx dizzy. its not going to run good at all. use the Y8 dizzy.
d: buy a GSR or LS (96 to 98 ob2) harness, you will be left off with one or two plugs but you will have ob2 connections. you dont even have to worry about your o2 sensor since its already 4 wire on the integra harness.
e: use your stock mounts from the DX change them all!
[b]My bike is faster than all your CIVICS combined!
MarkN929RR is offline   Reply With Quote
Del Sol S D15B7 to D16y8 swap question oakley2002@cox.net HYBRID -> EG-EK / DC 1 01-21-2004 01:32 PM
WTB: D16Y8 Swap Travis3265 Parts: For Sale/Trade/Wanted 5 11-12-2003 10:05 PM
Swap D16Y8 -> B18C5 CoupeLG HYBRID -> EG-EK / DC 1 10-05-2003 05:15 PM
D16y8 Swap freshclive HYBRID -> EG-EK / DC 4 04-18-2003 05:41 PM
