I came across mini-me setups for crx si's but only on the 2nd gens.
I was wondering is it possible to do this on a 1st gen? If so what is the difference in swaps if any? I do know this the 87 is 1500cc ,the 88-91's are 1600cc and the heads come off of 1600cc engines but i always hear of b18 heads on b20 blocks so is this possible? Given the fact that their all d series engines should'nt they all match up? ![]() |
Not to familiar with a 87 or older CRX, but it should work...It works on any D15 on a 2g rex, 4g civic, or 5g civic. Basically, you need everything involved with the head--complete head, distributor, intake manifold, P28 ECU, wiring harness, Z6 timing belt. For more knowledgeable information about a 2 rex, check out http://www.geocities.com/teampimports/svtec.html
My skin is singed but it heals my heart and with glowing pride I'll wear my scars. I'm honored by your hatred! She wanted love, I taste of blood. She bit my lip and drank my warmth from years before. |
It it possible to do a mini swap on a D15z6?? can i change it into D16z6? or is it like a complete swap?
![]() __________________
<span style=\'color:red\'>H<span style=\'color:black\'>onda</span> <span style=\'color:red\'>R</span><span style=\'color:black\'>acing</span> <span style=\'color:red\'>T</span><span style=\'color:black\'>eam</span></span> |
#4 | |
Member of the 20 nut club
virtually any D series non-VTEC engine can be converted to a mini-me with one of the D series VTEC heads.... you will run into different wiring issues depending on the year and model of the car that you are putting the setup into...
so in almost any case the answer to the question: "can i make a mini-me out of ________?"... is yes __________________
МОΛΏΝ ΛΑΒΈ |
#5 |
Cool, thanks so I guess by what you're telling me is it is possible to do the swap.
However do I have to use the ecu from the head I plan to install? Yes I'm thinking since it is v-tec I would need a computer to run it true? |
#6 |
Banned
you won't need the computer for the head but you will have to wire for v-tec and tap some lines and things of that nature........you could use a v-afc from apexi.....but with the sohc i don't think it will be necessary...(waist of money).
#7 | |
you dont need the ECU that matches the head... but it is a good idea to use it... otherwise your fuel map will be wrong and shit like that.... get a P28 they are pretty cheap
МОΛΏΝ ΛΑΒΈ |
| D15B7 vs. D16Z6 Head Bolts | Bigmojoj27 | HYBRID -> EG-EK / DC | 2 | 04-14-2004 02:22 PM |
| d16a1 DOHC head onto d16z6 SOHC block? | civic2nr9177 | HYBRID -> EG-EK / DC | 1 | 03-22-2004 12:14 AM |
| d16z6 head into 1992 civic cx | bricrx | HYBRID -> ED-EF / DA | 1 | 08-26-2003 05:16 AM |
| Wanted : D16Z6 Complete Head | Havok | Parts: For Sale/Trade/Wanted | 8 | 10-21-2002 11:33 PM |
