Ride: 93 civ b20w/b16 trans
I have a 1993 honda civic 4Dr b20z w/b16 trans recently my engine light started flashing and im no pro but it is giving me the codes 7 and 20 or 27? i was wondering if this ahd anything to do with my problem? its like the only lights in my whole car that work are the dome light and the headlights, and they taillights come on when i brake.. any help plzzz!!?
Ride: dc5,mk4 gti,2nd gen civic,92 accord cp,88 crx hf
well there is no code 27 and im not sure if code 20 could mess with that, thats the electrical load detector. but i would check my fuses first. and code 7 is the throttle position sensor so thats not gonna do it
Greenhorn
I had the same problem with my integra it is the same fuse for dashlights and taillights (probobly so that you know your taillights are out) it would randomly blow the fuse and I hunted it down and one of the wires for my marker light in the front was shorting out when i turned the lights on because it was pinched behind the headlight.. have you done anything to your headlights/taillights recently that may have caused something like that to happen? its just an idea or somewhere to start
#4 | |
#7 |
Ride: JRSC B20/vtec DC, Nissan Xterra SE
dude you almost definitely blew the fuse... like previously stated, the tails are on the same fuse as the dash lights so that you know when they dont work.
the dimmer switch (the dial that lets you dim or brighten the dash lights) is on that same circuit so it is possible theres a short there... but first thing to do is check the fuse! |
#8 | |
| Tags |
| b20, civic, codes, dash, ecu, honda, lights, tail |
| reverse lights dont work - 92 EG | CRXratedR | ECU's, Electronics, and Tuning | 3 | 05-03-2008 03:20 PM |
| turn signals dont work | 90htchbck | ECU's, Electronics, and Tuning | 1 | 10-04-2007 07:18 AM |
| Headlights and taillights dont work?!? | 92CHB | Civic and del Sol - EG and EK | 2 | 09-16-2007 05:07 PM |
| Vtec dont want work | shifter | General Tech and Maintenance | 2 | 04-07-2006 09:45 AM |
| My Lights Dont Work No More | Canuck 93 Civic Si | ECU's, Electronics, and Tuning | 5 | 03-20-2003 04:40 PM |
