DC radiator in EG?
Old 08-03-2007, 09:37 PM   #1
Ride:  92 Civic Hatch
Rep Power: 7 random_hero is on a distinguished road
Default DC radiator in EG?
I just bought an Integra radiator for my EG. I've heard they can be used as upgrade in EG w/B-series swaps. Do I need anything other than what I already have? Trading half size for fullsize.
Quick! Don't just do something, stand there!
random_hero is offline   Reply With Quote
Old 08-03-2007, 10:07 PM   #2
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
dont see why it wouldnt work.. you may have clearance problems if you have a aftermarket header..
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 08-04-2007, 03:18 AM   #3
Rep Power: 6 1BADEGDC2 is on a distinguished road
i put one in my eg, but then again i also put the whole integra front clip on my car .lol. your gonna need to add the little things that make the radiator sit. theres two of them. test fit it also because i spaced my radiator support about 1 1/2 inches up. Let me know how it goes or if i just made myself sound stupid.
1BADEGDC2 is offline   Reply With Quote
Old 08-04-2007, 07:33 AM   #4
Ancient Member
welfare's Avatar
Ride:  RHD EG6 jrsc b18c :)
Rep Power: 29 welfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the roughwelfare is a jewel in the rough
Send a message via AIM to welfare
In order to put the DC radiator into the EG you will have to get a chiesel or similar cutting tool and cup off all of the lower radiator and a/c condensor mounting brackets.
You have to be careful removing the 2 radiator bracket ones because you will have to re-use them. Now take a good hard look at where you want to put the DC radiator and mark the heaght you want it to sit at etc. Make sure you have clearance for the hood.
Measure the distance from in to pin on the bottom of the integra radiator (I think it's 22 inches but make sure you check it)
CEnter the 2 mounts and weld them inmaking sure they go in the same direction they came out.
Now for the top you have a couple options, you can either use OEM integra mounting brackets or you can make your own, the old civic bracket will not work
You have to line up the brackets making sure there is room between the top of the radiator and the support (otherwiss it may rub and damage the radiator) and then use self tapping screws to attach the brackets (unles you have a riv-nut gun)
9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6
doing it myself!
6/1/09 RHD on the road, now time for Body Shop
7/10/09 jackson gsr into rhd+hondata
91 rex ls/vtec
b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER!
13.881@102 on street tires
Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some
reptation, then give 'em a point!---,
welfare is offline   Reply With Quote
Old 08-04-2007, 11:46 AM   #5
thanks for the info. The teggy radiator is the same height as the eg radiator so its just a matter of positioning the brackets.
Old 08-04-2007, 12:35 PM   #6
Ancient Member
welfare's Avatar
Im not 100% that it is the same height, I would check it if you haven;t already, I am pretty sure it is, but I would check it just to be sure.
I am curious tho as to why you didn't jsut get a readiator for a 99-00 honda civic Si, it is the same size as the EG radiator and uses the same mounting location and everything, it also has the larger water nexks to use with the B series engine (since the Si is the b16) It is what I always use
doing it myself!
91 rex ls/vtec
Old 08-05-2007, 04:10 PM   #7
Rep Power: 7 loverboy is on a distinguished road
Look in this link shure it will be very helpful !!
HYBRID: Integra GSR Radiator EG Install
loverboy is offline   Reply With Quote
