| | LinkBack | Thread Tools |
| | #1 |
| Junior Member | i have a 93 civic ex OBD1 and i'm putting a 97' B18c1 OBD2 in it i am using my stock wiring harness..the only thing is that i don't know which ECU i need to use..someone told me i needed to use a OBD1 GSR ECU but when i look at the ECU reference chart on this website it says that from 94 - 01 they all use the P72 so does that mean that all GSR ECU's are the same regardless of OBD and that i can use the one thats coming with my swap?? |
| | #2 |
| Senior Member | no, they are not all the same- there are OBD I and OBD II P72 ECU's- the GSR's that were made for 96 and after obviously had to be OBD II- for your swap you're looking for an OBD I P72 from a 94-95 OBD I gsr or you could run a chipped P28, but i don't know much about chipped ECU's- E is running that setup though, he could help you if interested |
| | #6 |
| Senior Member | In order to retain the IAB function, you must have a P72 ECU. If you use the P28, the butterflies will stay still and only let you use the short runners, resulting in a low-end power loss. |
| | #8 | |
| Neighborhood Lush | Quote:
Another option, that i am considering for myslef, would be the P28, with a skunk or some other aftermarket intake manifold. no secondaries to worry about that, no knock sensor wires to run, just have to rechip it for redline and fuel delivery. -Chris | |
| Zc swap NEED HELP!!! | u8rice2 | HYBRID -> ED-EF / DA | 8 | 06-29-2004 05:53 AM |
| Big problem W/ H22 vtec swap HELP!!! | Jason C. | HYBRID -> BA-BB /CA-CD | 4 | 05-30-2004 01:37 AM |
| LS SWAP ON DEL SOL HELP!!! | wallasol | HYBRID -> EG-EK / DC | 4 | 03-03-2004 02:53 PM |
| 2nd gen Integra Swap Info | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:16 AM |
| Engine Swaps 101 | pissedoffsol | Swap Articles | 0 | 01-11-2004 06:54 PM |
