easy vtec question
Old 04-21-2004, 11:59 AM   #1
Rep Power: 13 civic-style is off the scale
does vtec only engage when the engine is at operating temp?
civic-style is offline   Reply With Quote
Old 04-21-2004, 12:05 PM   #2
Rep Power: 13 LOS222 is off the scale
From what I have heard , YES
LOS222 is offline   Reply With Quote
Old 04-21-2004, 12:11 PM   #3
thistownsucks...
hybrid89's Avatar
Rep Power: 33 hybrid89 will become famous soon enough
Send a message via AIM to hybrid89
yes. your motor needs to be at a certain predetermined (ECU) temp and oil pressure for vtec to engage, if it running from the ecu. if you have vtec hooked up to an RPM switch(ie MSD) the no, it will engage either way.
matt
id rather have a hondata and a stock block
then a sleeved, pistons/rods combo and a hack or fmu
hybrid89 is offline   Reply With Quote
Vtec Solenoid Troubles RandomTask76 HYBRID -> EG-EK / DC 5 05-20-2009 01:05 AM
VTEC Controller? Just VTEC Control Accordturbo94 ECU's, Electronics, and Tuning 11 12-23-2003 02:42 AM
Y8 Head Swap Question. Need Help. All Show HYBRID -> EG-EK / DC 3 08-20-2003 04:09 PM
Vtec Issue On B16 Swap hondadriver HYBRID -> ED-EF / DA 6 05-20-2003 11:49 AM
Easy Question alabranche HYBRID -> EG-EK / DC 2 03-19-2003 03:22 PM
