ek b20????
Old 10-19-2009, 05:34 PM   #1
Rep Power: 1 Rjs4490 is on a distinguished road
Default ek b20????
my buddy is just finishing his swap and hes tryin to get an estimate of what hes gonna be runnin as far as quarter mile time heres a list of his motor and what hes got done
b20b with 4k miles, skunk2 intake mani, blox 66mm t.b, megan racing 4-2-1 headers, 2.5 apexi worldsport, CAI, si tranny, f1 stage 3 clutch, 8 lb fidanza flywheel, hasport mounts, avid lightweight shift linkage, block gaurd, arp head studs, cometic head gasket, and a decent set of tires.
if any1 has any ideas about what kinda times he will be runnin let me know, and let me know what you think of his setup.
Rjs4490 is offline   Reply With Quote
Old 10-19-2009, 06:33 PM   #2
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
anywhere from 14's to 17's depending on how stripped down the car is, and how good of a driver he is.
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 10-19-2009, 06:42 PM   #3
Dark93DX's Avatar
Rep Power: 10 Dark93DX is on a distinguished road
Well I didn't see anything in that list about what ECU he is using so he wont be running at all.
Why did he use a block guard?
K20Z3 EG - Installed, waiting for Kpro
LSD w/ 4.764 FD
B18A CRX
Dark93DX is offline   Reply With Quote
Old 10-19-2009, 10:49 PM   #4
O my bad he is runnning a spoon tuned p75, and he's a really good driver. And the block guard was for vtec but I think he changed his mind about that... not sure. But does any1 else have any idea about how it should do, or have a similiar build.
Old 10-19-2009, 11:24 PM   #5
Christmas Car
Ride:  93 4dr D15B, Greddy Short Ram, 4-2-1 Header, 2.5" Exhaust.
Rep Power: 8 RoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura about
Spoon tuned as in legit Spoon Sports tuned? Or $15 ebay Spoon chip tuned?
Please direct your questions in the following format.
1) Did I search it on Google?
2) Did I use the search function in the TOP RIGHT AREA of this page?
3) Refer to Step 1 and 2.
If that doesn't work, then feel free to post.
RoughKnight is offline   Reply With Quote
Old 10-20-2009, 12:04 AM   #6
Exclamation
LEGIT Spoon Sports tuned for everything done to the car!
Old 11-03-2009, 01:55 AM   #7
anybody else have any thoughts on wha the car might do as far as a quarter mile time or anything???
Old 11-03-2009, 12:20 PM   #8
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
If it's Spoon tuned then he should know what it made at the wheel.
Also, what transmission is he using? LSD?
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 11-03-2009, 07:27 PM   #9
Rep Power: 0 intenseneal can only hope to improve
My EK with an Ls swap just ran a 16.171 @ 85mph. This was with one missing motor mount and was still learning the new motor. But even then I lost a second on my ET. Was running 17.2s and 17.3s before the swap. Ls and B20 swaps in coupes run high to mid 15s. This is in stock form, no intake mani, cams, tuning, header, exhaust. With some work you can see high 14s, that is my goal. Best way to find out what it will run is to take it to the track and find out
intenseneal is offline   Reply With Quote
Old 11-08-2009, 12:45 PM   #10
he is usin an si tranny, he also has hasport solid motor mounts, avid light weight shift linkage, skunk2 short throw and shifter, and energy suspension shifter bushings. the p75 ecu was tuned by spoon prior to being put in th car, had to go through a long process online about what was done to the car and what wasnt for a specific tune.
Old 11-08-2009, 12:46 PM   #11
and no lsd... yet. .
Old 11-09-2009, 11:46 PM   #12
The Si tranny wont make that much difference than the S80 Ls tranny, maybe .1 second. I also have a DC short shifter, Engery Suspention shifter bushings, custom 2.25 catback and CAI. And the motor mounts wont do much as well. The ECU, flywheel, clutch, intake mani and header are best mods listed. As I said before you should see low 15s maybe maybe high 14s, if you can get the traction. That is my biggest issue at the track is hooking up, tires break loose even going into second. And off the line I have to stay under 2k or the tires just spin. Run the car and find out thats the only way to know what it runs.
Old 11-10-2009, 12:08 AM   #13
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
If that's true then why does anyone bother upgrading to shorter-geared transmissions? Where are you getting your facts here?
PSN Network ID: BrutalB83
Old 11-10-2009, 04:25 PM   #14
he said that if he hits low 15''s he will be embarressed and sell the car. lol. and obviously the shorter geared tranny is gonna be perfect for the car considering that b20's dont rev high. some1 is clearly missinformed
Old 11-10-2009, 04:27 PM   #15
in the same car before the swap he had a d16 non vtec with a shitty intake and exhaust and a fpr and an ls fuel rail and injctors... that it. so low 15's would be badddd lol
Old 11-10-2009, 09:21 PM   #16
mdpsEG's Avatar
Ride:  JRSC B20/vtec DC, Nissan Xterra SE
Rep Power: 43 mdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant futuremdpsEG has a brilliant future
i would think he should be able to get into the 14s if he can drive. im still wondering about the tuning though.... if it was dyno tuned the way it should be, he would know the whp and we could make a better guess. if its running on a "spoon" modified basemap then the car is not running to its full potential.
mdpsEG is offline   Reply With Quote
Old 11-10-2009, 09:35 PM   #17
Ride:  99 ex, d16y8 PnP, headers, exhaust, crower cam, 135whp
Rep Power: 4 josh_crewdson@y is on a distinguished road
dont rev it too high, rod bolts will flying... get it tuned correctly on a dyno..
josh_crewdson@y is offline   Reply With Quote
Old 11-11-2009, 02:49 AM   #18
o as soon as its all set(which should be next sunday) it will b hittin the dyno and ill be sure to post his numbers. but still lookin for more opinions on the build. let us know what u think. o and ill post pics asap.
Old 11-11-2009, 07:45 PM   #19
I kow the Si trans has shorter gearing, just saying you are not going to see a huge diff in ET compaired to a S80. Keep in mind that the P75 head is not the best flowing head Honda makes. The head is where the power is made not so much with bolts ons. Bolt ons support the head and will yeild more power with cams and a p&p. Knowing how much tq and hp will help alot, I agree. Lets say you make 130-140whp (that seems about right?) then you should hit low 15s. Why would you sell the car if it runs low 15s?? That is good for a non Vtec non turbo Civic coupe. With a Vtec head swap 200whp is very easy to make. Then you will hit low 14s high 13s. Also what size rims and tires are you running and what tires??
Old 11-19-2009, 02:47 PM   #20
MB4 X2
IanB's Avatar
Rep Power: 5 IanB is on a distinguished road
The tune is a guess at best, get a real tune specific to how that motor runs. You have no idea if this Spoon tune is safe, let alone optimized for power. I also didn't see any mention of cams in your mod list, but that Skunk2 IM will push your powerband up and out of the stock cams (and the stock redline) operating range. That intake manifold might hurt more than help in this application to be honest.
High torque motor (for a Honda anyways), short ratio tranny, no LSD, sounds like a recipe for wheelspin to me. If your buddy can get it to hook, he might see high 14's, but he shouldn't be disappointed if he runs low 15's, that's just being realistic.
'99 Acura 1.6EL Premium VSM 5M
'98 Acura 1.6EL Sport VSM 4A
IanB is offline   Reply With Quote
