ek wiring for b16
Old 01-05-2005, 12:57 AM   #1
Rep Power: 0 qtmac_mien has a little shameless behaviour in the past
Send a message via AIM to qtmac_mien
anyone who has done the b16 swap wit the EK using the d16y7 harness, can you please tell me which plugs fit onto the motor without modifying it and all the plugs i need to re-wire to fit the motor?? im goin with the b16 block wit the cable tranny (got 2 for free from cousin), p28 (got the jumper harness), 97 gsr dizzy etc.. just need the wiring done rite...
AIM: shrtxqtxmienxboi
email: qtmac_mien@hotmail.com
qtmac_mien is offline   Reply With Quote
Old 01-05-2005, 11:30 AM   #2
Ride:  RX5.7 Civic LS and Teg Ls
Rep Power: 25 civiclxb16 will become famous soon enough
Send a message via AIM to civiclxb16 Send a message via Yahoo to civiclxb16 myspace
basically if you can have the two motors side by side unplug one wire from your stock engine and plug it in the b16 that is what i did with my swap all the wires pretty much match up with the b16 from the d16, if you can get your hands on a helms if you need a copy of it let me know i have it on cd and i sell them for 5 bucks shipped if you need it. SO2S, CKFM, SO2H and PO2H are not going to be plugged in tie them up and put them away. you are also going to need to do the three wire to two wire convertion it is on the bottom of the pic here, good luck
by the way i did the same swap in my 96 and if you can get rid of that cable tranny get a gsr one or a ls on
Check Out My Car Club
www.HighRevCustoms.com
and join the forums
this is what happens when you are bored out your mind!!:|
my current baby http://i114.photobucket.com/albums/n.../myspacefc.jpg
civiclxb16 is offline   Reply With Quote
Old 01-05-2005, 07:41 PM   #3
thanks alot that really helps alot.. and yes i have a helms also but i was tryin to find a easy and fast way to do my wiring bcuzz i need it done really fast bcuzz im leavin really soon and i need it done so i can drive it...thanks alot.
