Engine Harness Question
Old 11-17-2007, 07:42 AM   #1
Importfan's Avatar
Ride:  Yamaha R6 2000 EK
Rep Power: 6 Importfan is on a distinguished road
Default Engine Harness Question
i swapped a Y8 into a 94 ex coupe and i picked up a 93 SI engine harness for a good price but it was out of a canadian 93 SI. Wanted to know if the alternator wire colors mean the same as the US ones. this being for when i splice the new plug onto the harness to fit it. reason i ask is because ive been throwing the CEL 20 (electrical load detector) at high RPMs. O one other thing, what would cause the CEL 7 (TPS) also when i get on it. Then when i shut the car off and turn it back on the CELs are gone.
any input would be great
Importfan is offline   Reply With Quote
Old 11-19-2007, 04:04 AM   #2
Honda Master Technician
norcalgsr's Avatar
Ride:  88 Prelude Si and a CBR 600 Hurricane
Rep Power: 21 norcalgsr is a jewel in the roughnorcalgsr is a jewel in the roughnorcalgsr is a jewel in the rough
myspace
The TPS is a typical problem on used engines.. either check it with a multimeter or replace it and it should take care of the TPS code.
Do not PM with tech questions without providing a link to your topic on the forums. This way everyone has access to the information..
norcalgsr is offline   Reply With Quote
Old 11-19-2007, 05:24 AM   #3
Regular Member w/ Cheese
YBLEGAL's Avatar
Ride:  2000 EJ8 w/ SiR-II
myspace
yeah use the multimeter like he said, but to clarify; put the key in on with the engine off, then test the voltage accross the signal and ground. it should read .45~.5v closed throttle, and 5.0v full throttle. since your having issues at full throttle, try rotating it open slowly, watching the voltage all the while and make sure it increases smoothly.
Engine swap d16y8(obd2a) to b18c4(obd2b) UKDM, harness Q. hlt ECU's, Electronics, and Tuning 1 01-19-2007 05:45 AM
gsr whp 94_gs-r Engine Building 100 01-15-2007 10:00 AM
engine harness question..... slammedcivic HYBRID -> EG-EK / DC 4 04-08-2006 11:26 PM
wiring harness question mrnice1058 HYBRID -> EG-EK / DC 4 07-02-2004 08:20 AM
ecotec tweakman Members' Lounge 22 09-29-2003 03:23 AM
