Engine Mount Help?
Old 01-25-2006, 07:20 PM   #1
Rep Power: 8 Ignorant import guy is off the scale
What engine mount kit do I need to swap a B16A2 into my 1999 Civic EX non-VTEC. Where could i find a good price for the kit?
Ignorant import guy is offline   Reply With Quote
Old 01-26-2006, 05:29 PM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
Rep Power: 529 pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
nothing if the b16a2 is from the 99-00 civic si. use those mounts
Old 01-26-2006, 06:41 PM   #3
<div class='quotetop'>QUOTE(pissedoffsol @ Jan 26 2006, 05:29 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
i plan on buying a JDM B16a2...does that change anything
Old 01-28-2006, 12:03 AM   #4
Rep Power: 14 killercannible will become famous soon enough
All b series engines have the exact same mounting holes and the transmissions are the same, excluding cable transmissions. All you need for this swap is a 99-00 si rear mount. If you want it to be really stiff (recomended) get the torque mounts too. Also get the mount inserts while you are at it, they are cheap and will really help you.
Got my swap!!! Needs to be faster.
killercannible is offline   Reply With Quote
Old 01-29-2006, 10:56 PM   #5
RETIRED
<div class='quotetop'>QUOTE(killercannib le @ Jan 28 2006, 12:03 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
100% false.
<div class='quotetop'>QUOTE</div><div class='quotemain'>
[/b][/quote]
true
<div class='quotetop'>QUOTE</div><div class='quotemain'>All you need for this swap is a 99-00 si rear mount.
[/b][/quote]
false. the rear mount and the 99-00 si drivers side mount is needed. the teg one won't work.
ALL of this is covered in our 6th gen swap guide in the Swap Articles forum.
<div class='quotetop'>QUOTE</div><div class='quotemain'>If you want it to be really stiff (recomended) get the torque mounts too. Also get the mount inserts while you are at it, they are cheap and will really help you.
[/b][/quote]
torque mounts are over-rated IMO, but are good to have if you are using the stock mounts.
Old 02-09-2006, 07:41 PM   #6
Rep Power: 0 spoonracer84eg is off the scale
<div class='quotetop'>QUOTE(Ignorant import guy @ Jan 26 2006, 06:41 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
[/b][/quote]
Im not trying to be a smart ass but there isnt a JDM B16a2. There is a JDM B16 Sir ll. Thats probably what you meant. JDM motors do not have numbers after the "a" or whatever letter is there.
spoonracer84eg is offline   Reply With Quote
Forum Jump
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
