Hello. I have a 1994 Civic. I swaped out my d series engine for a b18c. Its a JDM GSR. I keep throwing a engine light for a knock sensor. I changed the sensor, and it didnt fix the problem. I had to wire the vtec and other needed wires for my swap. I purchased a swap harness kit that had all the needed wires in a sub harness that just plugged into the ECU. All the wires look good and are stongly connected to the ECU. Light will not go out. Any info or tips would be great.
wwtdd?
nope, but you can do a search. it's posted a million times on this forum.
oh, and start your own thread. __________________
Warning: If you are reading this then this warning is for you. Every word you read of this useless fine print is another second off your life. Don't you have other things to do? Is your life so empty that you honestly can't think of a better way to spend these moments? Get out of your apartment. Meet a member of the opposite sex. Stop the excessive shopping and masturbation. Quit your job. Start a fight. Prove you're alive. If you don't claim your humanity you will become a statistic. |
#7 |
Make sure you have the knock sensor wire connected on the correct pin location D3=KS for Obd-1 only.
http://hondaswap.com/parts-sale-trad...-parts-233166/ |
#10 | |
Supra & Civic-T Owner
Ride: 87 Supra Turbo and Civic d16 turbo going h22
dont quote me on it but i believe if youare running and obd1 you can disable the knock sensor without any engine effects this will take away the engine light. some people have to do this when using p28. liek i said dont quote me but look into it i think it may be your issue |
#13 |
Just disable it won't affect your performance
#15 |
Knock sensor is disabled on the eprom inside the ecu meaning it would have to be chipped.
| LS swap civic check engine light on | BIGJOSEPH | Civic and del Sol - EG and EK | 17 | 02-01-2008 03:41 PM |
| b16 check engine light | MikeCrvtec | ECU's, Electronics, and Tuning | 2 | 12-11-2006 10:16 PM |
| check engine light | shootist | General Tech and Maintenance | 3 | 11-22-2004 02:12 PM |
| check engine light | EG6D16Z6_NA | General Tech and Maintenance | 4 | 10-17-2003 05:26 PM |
| Check engine light | Ractive78 | ECU's, Electronics, and Tuning | 0 | 08-22-2003 11:52 PM |
