i HAVE A 97 CIVIC HATCH DX. MY BROTHER GAVE ME A 95 INTEGRA LS MOTOR. WHAT MOTOR MOUNTS WILL I NEED TO PUT THE CAR IN MY HATCH? WHAT AXLES SHOULD I USE? i KNOW I'M GOING TO HAVE TO BUY THE CONVERSION HARNESS FROM OBD II TO OBD I. IS THERE ANYTHING ELSE I SHOULD KNOW?
wILL A 99 LS ENGINE WIRING HARNESS FIT A 95 LS? |
Go fast, Go Cheap
Ride: Hybrid POWER!
i HAVE A 97 CIVIC HATCH DX. OK
MY BROTHER GAVE ME A 95 INTEGRA LS MOTOR. nice swap that in, why are you yelling? WHAT MOTOR MOUNTS WILL I NEED TO PUT THE CAR IN MY HATCH? teggy mounts. WHAT AXLES SHOULD I USE? Integra axles too, you're still yelling? You need the tranny, too just incase you don't have it. i KNOW I'M GOING TO HAVE TO BUY THE CONVERSION HARNESS FROM OBD II TO OBD I. IS THERE ANYTHING ELSE I SHOULD KNOW? ecu would be handy to have too. walk quietly and carry a big stick. wILL A 99 LS ENGINE WIRING HARNESS FIT A 95 LS? dunno, search? __________________
Resurrected Sol http://hondaswap.com/auto-multi-medi...ted-sol-60210/ 2003 Civic Hybrid (I'm a grown-up now) www.myspace.com/burdenelectronica |
B happy
Ride: dohc 95 egg
YOU ARE GOING TO HAVE ISSUE WITH THE WRING HARNESS BECAUSE THE OBD II CIVIC HAS A ONE PIECE AND THE INTEGRAS HAVE A TWO PIECE, UNFORTUNATELY YOU OBD II CIVIC HARNESS WILL NOT PLUG INTO THE OBD I LS MOTOR. YOUR BEST BET IS GOING TO BE GETTING AN OBD II INTAKE MANIFOLD, AND DISTRIBUTOR TO UPDATE THE ELECTRONICS ON THE MOTOR TO FIT TO THE CIVIC AND THEN USING THE CIVICS HARNESS. THEN FIND YOURSELF AN OBD II LS ECU AND PLUG IT IN. YOU ALSO WILL NEED THE INTEGRAS AXLES, SHIFTLINKAGE, AND THE REAR MOUNT FROM A 99-00 SI.
Turn off teh caps lock please ![]() __________________
