ES motor mount inserts
Old 01-19-2006, 06:30 AM   #1
Rep Power: 0 Axel is off the scale
Send a message via MSN to Axel
Thumbs up
I'm buying inserts for my mounts in my 97 coupe. It's getting a b16a swapped in and i was wondering what kind of inserts i will have to order.
96-00 For "all" civic (except 99-00 Si) 16.1105
99-00 Civic Si 16.1106
It is after all a 96-00 with a b-series engine. So will i have to order inserts for the Si then? Or should it work with the kit for "all" 96-00 civics?
-Thanks.
-97' Civic Coupe iLS/DX (d16y7) B-series coming.
Axel is offline   Reply With Quote
Old 01-19-2006, 03:39 PM   #2
Rep Power: 29 VTECPOWER is off the scale
Send a message via AIM to VTECPOWER
depends upon which mounts you use, oem civic si or aftermarket like hasport?
DB8 450whp project......
VTECPOWER is offline   Reply With Quote
