Exhuast
Old 09-23-2003, 11:23 AM   #1
Rep Power: 0 tag6977 is off the scale
I decided to buy a Apex N1 for my B18b Civic HB. My question is should I get the exhuast for the HB or should I get one for the B18b? The piping is the same, but I'm sure the muffler and cat will be different. I don't want to have an extension welded onto a brand new exaust if I don't have to. So which one would be better to go with?
tag6977 is offline   Reply With Quote
Old 09-23-2003, 11:35 AM   #2
Rep Power: 16 Teambypass is off the scale
Go for the exhaust for the hatch. I have a 96 cx hb and my full cat exhaust is from a 92-95 hatch and it fit perfectly.
I am not in2RACING, RACING is Me!
96 cx hb with 98 JDM GSR, IB probe 12:3:1 7.1cc pistons, IB ultralite rods, skunk2 stage2 camshafts, valves, springs, retainers, cam gears, skun2 intake manifold, Eldelbrock 65mm throttle body, 4-2-1 DC, Quaife LSD, Findaza flywheel, Fsudo cat back with OBX high flow cat, a valve job with light port and polish, hodata s200, walbro 190 fuel pump, RC370cc injectors, and AEM fuel rail & regulator, NGK spark plug wire.
STOCK BEST ET: 14.7 AT 95.3 mph.
WITH MODS BEST ET: 14.2 AT 99.8 MPH
Teambypass is offline   Reply With Quote
Old 09-23-2003, 12:09 PM   #3
exhaust matches the chassis, header matches the motor, and the cat/test pipe is to be made.
13.3@103 MT's &amp; Gutted
-Project 5 - Motor A (???)
Which Exhuast System brian11to1 General Tech and Maintenance 30 03-11-2004 05:14 PM
what exhuast should I get? jeffie7 Members' Lounge 15 03-04-2004 07:02 AM
FS:Integra exhuast on e-bay!! 12secondCRX Parts: For Sale/Trade/Wanted 6 02-27-2004 11:54 AM
Need help with exhuast kn_racer HYBRID -> EG-EK / DC 1 10-16-2003 03:40 AM
what exhuast system to use...??? dvus1 Engine Building 2 07-15-2003 01:33 AM
