(F20C-S2000)+(F20B-Tranny)=FWD 250HP
Old 01-18-2005, 09:05 AM   #1
Riceras is off the scale
Send a message via AIM to Riceras Send a message via Yahoo to Riceras
I think this swap would be great?
Question to drop this into an EK9 would I just get the hasport kit to drop in an H22?
Would this actually work though I dont know the F-Series Very Well!!! B)
Riceras is offline   Reply With Quote
Old 01-18-2005, 09:18 AM   #2
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
i think the f20c spins in the opposite direction, also the mount locations are in different places.
I doubt the f20b trans bolts up to it.
You'd be much better off with an h22 or any be series turboed or whatever to make the 250 goal.
92civicb18b1 is offline   Reply With Quote
Old 01-18-2005, 09:28 AM   #3
Ride:  RX5.7 Civic LS and Teg Ls
civiclxb16 will become famous soon enough
Send a message via AIM to civiclxb16 Send a message via Yahoo to civiclxb16 myspace
i was wondering if it worked as well i wish it did tho but he is right it spins in the opps direction
civiclxb16 is offline   Reply With Quote
Old 01-25-2005, 07:05 PM   #4
nismogod is off the scale
Send a message via AIM to nismogod
i'm under the impression that the f20c is nothing like the other f-series engines. just like the b20 in the old preludes isn't like the other b-series engines.
nismogod is offline   Reply With Quote
Old 01-25-2005, 07:29 PM   #5
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
You can mash the K series transmission and the F20C together and try to drop it into an EK...
Old 01-25-2005, 07:34 PM   #6
dohch22a4's Avatar
dohch22a4 is off the scale
Send a message via AIM to dohch22a4
The F20C is pretty much an even more asskicking K20A. The designs are very similar and I've even heard that the cams are interchangable. The look like the same friggin motor other than the intake manifold and the fact that it's a RWD engine.
dohch22a4 is offline   Reply With Quote
Old 01-26-2005, 01:03 PM   #7
If that was possible think of the Possibilities??????
I would love to have ALL-Motor 250HP Stock FWD
Old 01-30-2005, 12:46 AM   #8
ej11's Avatar
ej11 is off the scale
HAHAHA!!!!!
I WAS THINKING THE SAME CHIT THE OTHER DAY...
(F20C,F20B TRANNY... TO BAD IT WON'T WORK...WILL IT?
ej11 is offline   Reply With Quote
Old 01-31-2005, 12:28 PM   #9
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
you can. you just need to build it.
k24 tsx block
k20a jdm itr head
add
i/h/e
250 crankhp for sure.
Old 01-31-2005, 12:31 PM   #10
learning in progress
formby's Avatar
formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
i was looking into that swap but at the moment its way to expensive and time consuming
