Final Swap Info
Old 04-20-2004, 09:23 PM   #1
Rep Power: 13 95hatchcx is off the scale
I am going to do my swap next week. I have a 1995 Honda Civic CX hatch. I am swapping a B18B Ls.
I have all the motor mounts from the ls, i use the front and rear tranny mounts from the civic correct?
I need to change the o2 sensor to a 4 wire? if so how do i wire this up?
can i use the Civic wiring harness? my ls harness has been cut
i use the ls drive axles
i use the ls ecu
i use the ls throttle cable
i use the ls shift linkage
which radiator hoses do i use? civic or integra
Any other good information????
95hatchcx is offline   Reply With Quote
Old 04-20-2004, 09:25 PM   #2
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
for radaitor hoses, neither. If you have a civic radaitor, you need del Sol VTEC radaitor hoses.
For the 4wire O2 conversion, check the FAQ's
Collin
Material Science and Engineering
Michigan Technological University
Swap Info Needed mikescivic HYBRID -> EG-EK / DC 8 09-27-2006 04:51 PM
b16a swap info crx91hf HYBRID -> ED-EF / DA 9 08-16-2004 12:42 AM
Need some accord swap info Bump HYBRID -> BA-BB /CA-CD 1 03-28-2004 03:57 PM
b16a1 swap info RiDiNg SoLo HYBRID -> ED-EF / DA 4 03-26-2004 12:19 AM
Please Help! I Need Ls/vtec Swap Info KILLERHB HYBRID -> EG-EK / DC 3 03-08-2003 08:58 PM
