This is a discussion on Finally get it running and... in the HYBRID -> EG-EK / DC forum
93 civic civic b16 sir obd1 motor/tranny
So I have had my car running for a week and blew the tranny since my friend forgot to put in fluid... then I throw in another tranny and drive it for 2 days until a hole appears ...
| | #1 |
| 93 civic civic b16 sir obd1 motor/tranny So I have had my car running for a week and blew the tranny since my friend forgot to put in fluid... then I throw in another tranny and drive it for 2 days until a hole appears in it the size of a baseball... Finally get another tranny installed today, double check everything I take it out on the road and baby it through first and second then I hit the gas and rap it up to 7g's real quick. (pop) Backfire??? Then the car dies, So while I am still moving I try and start it back up and it won't start back up. It's trying to turn over it sounds like, but wont. I checked the ground on the starter and every other wire I could think of, but couldn't find anything other than the o2 sensor was loose. The car still won't start up. The timing belt is still tight and looks good... maybe I blew my motor??? Any ideas??? |
| | #2 |
| Have you looked at the spark plugs? That can give you a good clue to see what happened to the engine. If they look good, try a compression test or leak down test. Hope that helps! |
| | #3 |
| Are you getting spark? |
| | #4 |
| Not seeing any spark so the dizzy must be dead??? |
| | #5 |
| not so much the dizzy but the coil. |
| | #6 |
| So I pull off the dizzy and pull off the cap and plastic peices fall out with the rotor screw... hmmm yeah replacing parts... Thanks GuyS!!! |
| | #7 |
Similar Threads | ||||
| FINALLY got my h22a swap running | asmallsol | Auto Multi-Media | 12 | 08-17-2006 09:16 PM |
| it was running just fine | civiclxb16 | HYBRID -> EG-EK / DC | 17 | 01-31-2005 10:14 AM |
| CRVTEC Civic Is Finally Running | adidas_man | Auto Multi-Media | 11 | 09-22-2004 08:03 PM |
| ZC running rich | cheese9988 | General Tech and Maintenance | 6 | 05-31-2004 08:17 PM |
| swap finally done! | B16 | Auto Multi-Media | 26 | 04-16-2004 04:29 PM |
