I don't see the fuel injector resistors on this car. I'm currently working on an H22 swap and I know that the prelude uses the fuel injector resistors. Now I was wondering if its possible for me to wire it up without the resistors or do I have the get the resistors from the prelude?
-|\/\/\/\/\|- Ohmstable |
No you don't have one. What year/model swap are you doing? Some of the prelude are the same resistance as the Civic injectors.
<a href=\'http://www.knology.net/~jediklc/\' target=\'_blank\'>My Webpage</a> <a href=\'http://www.geocities.com/DawgSol94S/Welcome.html\' target=\'_blank\'>Team Sol Georgia</a> |
I'm not sure what year car the engine is from, It is however an JDM H22a. Is there anyway of knowing what year the engine is from the numbers on the block (right under where it says H22a)??
I'm pretty sure its from a 92-96 prelude. __________________
Well then check the resistance on the injectors. Compare your stock to the h22. there is a how to on my site if you don't know how, You will need a multi meter
#5 |
RETIRED
http://www.allmotorhonda.com/techpages/injector.htm
if your car is saturated, and the injecotrs are peak hold, you need a box if your car is peak/hold, and the injectors are saturated, you need a box |
#6 |
Actually I checked the resistance on the H22 injectors and they are ~3ohms so I'm going to have to install the injector resistors. Pain in the ass..
| Drag kit install manual | pissedoffsol | Forced Induction | 0 | 07-18-2004 12:37 AM |
| research paper, what do you think? | 90 accord | Members' Lounge | 9 | 06-23-2004 12:11 AM |
| Fuel system | Sed8ed | Engine Building | 2 | 05-26-2004 01:05 PM |
| 1st Gen CRX FAQ's | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:51 AM |
| Help on this fuel regulator gauge | Teambypass | HYBRID -> EG-EK / DC | 5 | 09-22-2003 02:02 PM |
