Fuse Keeps Blowing
Closed Thread
Old 04-30-2003, 02:47 PM   #1
Rep Power: 0 hf hoe is off the scale
What up everyone? I recently swapped a b16a into an 88 hf without a problem, but after driving it for about 30 minutes the 50A fuse, which is in the fuse box in the engine compartment, blew out. I replaced the fuse, but it blew out again, this time around 45 minutes(I wasn't actually timing it, just an estimate in case it helps). I was searching online for an answer, but all I got was that the 50A fuse is used for lighting, or at lest was. Any help is appreciated and thx in advance.
hf hoe is offline
Old 04-30-2003, 09:24 PM   #2
Rep Power: 21 deth101 is off the scale
Send a message via MSN to deth101 Send a message via Yahoo to deth101
my olny advise is my common prob,check grounds,and in my old jeep water in my light housing made the fuse go but the bulb went too,good luck.
</span><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE </td></tr><tr><td id=\'QUOTE\'>QUOTE (pyrohardcore @ Apr 22 2003, 06:56 PM)guess i'm sorta out in the open surrounded by fat kids in paintball tho </td></tr></table><span class=\'signature\'>
Evil Should'nt Look This Good.
deth101 is offline
Old 05-01-2003, 02:58 AM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
this thread is not swap related and has been closed.
please read where you are posting.
pissedoffsol is offline
Closed Thread
Fuse Keeps Blowing WTF!!!! B16RacerN2NR ECU's, Electronics, and Tuning 2 04-27-2004 09:53 PM
Just finshed swap but keep blowing a fuse Cambo HYBRID -> EG-EK / DC 2 02-02-2004 11:37 PM
Fuse Problem darwins_vtech HYBRID -> EG-EK / DC 0 09-12-2003 01:03 PM
Blowing Clutster/tail Light Fuse SleEPeR_CRX ECU's, Electronics, and Tuning 5 06-11-2003 03:07 PM
Blowing Fuse stud4u2c17 ECU's, Electronics, and Tuning 2 03-15-2003 01:20 PM
