GSR del sol
Old 10-26-2009, 11:45 PM   #1
Greenhorn
Rep Power: 0 89guts is on a distinguished road
Default GSR del sol
my battery light came on the other day so i thought it was my battery going weak and had it tested at autozone, it was bad so i replaced it with a new one and thought my problem was solved but it started to come on again and my idle would bounce up and down at stop lights... i had my alternator tested also that was not the problem and my connections are all good too, has anyone had similar problems?
89guts is offline   Reply With Quote
Old 10-27-2009, 07:40 PM   #2
Rep Power: 0 intenseneal can only hope to improve
Check all the connections at the battery, alt and that the battery terminals are clean. I would have the alt retested at a different shop. It is easy to get the alt draw test wrong if you dont know what you are doing. It sounds like a bad alt to me. Also make sure the belt for the alt is tight.
intenseneal is offline   Reply With Quote
Old 10-27-2009, 07:42 PM   #3
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Double check all of your grounds. Make sure they are clean and connected tight. Same with the power wires.. Make sure there is no corrosion building up anywhere.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
