Facebook Twitter
Gsr And Ls Wiring Harness.
This is a discussion on Gsr And Ls Wiring Harness. in the HYBRID -> EG-EK / DC forum
Which part of the gsr wiring harness do I need to use to swap my gsr motor into my ls? Do I need to cut any wires? I have the entire complete wiring harness from my gsr donor. I have all the dash wiring and ...
Old 06-03-2003, 08:51 AM   #1
Which part of the gsr wiring harness do I need to use to swap my gsr motor into my ls? Do I need to cut any wires? I have the entire complete wiring harness from my gsr donor. I have all the dash wiring and abs, every wire you can imagine. What part will I actually need to use? Just the engine wiring part?
97dc4 is offline   Reply With Quote
Old 06-03-2003, 10:03 AM   #2
pissedoffsol's Avatar
the your GSR and LS are the SAME obd, and obd1, use the motor harness, plug it in at the passenger side shock tower (3 connectors i beleive) and then run the 7 wires for vtec/IAB/knock
see: http://www.hondaswap.com/swap/viewer.php?id=57
Old 06-19-2003, 04:54 PM   #3
primo
Posts: n/a
What about for OBDII in same situation? i did the same thing.
Old 09-08-2006, 12:30 AM   #4
Question
so i am doing to same thing. i got a 1993 acura integra and i am putting a 1995 GSR. will i need the wiring harness from the gsr motor???
Fox_137 is offline   Reply With Quote
Old 09-08-2006, 04:35 AM   #5
VTECin5th's Avatar
Yes, use the GSR harness, add the wires from the ecu to the shock towers.
VTECin5th is offline   Reply With Quote
© 2001-2013 HondaSwap.com
