h22 civic help
Old 08-21-2003, 12:46 PM   #1
Rep Power: 0 jdm_civic93 is off the scale
i have a h22 in my civic and i was just wondering do i put the prelude fuel pump or the civic one is alright and also do i have to change the distributer because i have a 97-01 lude and the ecu is a 92-96 p13?
Any help would be apriciated
jdm_civic93 is offline   Reply With Quote
Old 08-22-2003, 04:57 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
get a walbro pump. 255lph. its like 90 bucks, and offers more performance than any honda one, and its half the cost.
as for your distributor, i don't know. i know nothing about h-seires. if it is like a civic/teg, the answer is no. but im not sure if it holds over for the ludes
Old 08-22-2003, 11:26 AM   #3
thanks for the help man
Old 08-22-2003, 12:08 PM   #4
Rep Power: 13 j3521 is off the scale
What wiring harness are u using, on my car I used the Civic harnes and just added the wires I need and repinned some of them, and used a OBD 1 P28 or u can use a P72 if u wire in the knock sensor.
j3521 is offline   Reply With Quote
Old 08-22-2003, 03:03 PM   #5
Im using the civic harness and i rewired the ecu and im using a p13 ecu
Old 08-25-2003, 07:34 PM   #6
Rep Power: 15 831civic is off the scale
wouldn't the 255lph fuel pump be too much fuel for a stock h22?
831civic is offline   Reply With Quote
Old 08-26-2003, 02:08 PM   #7
KMS-fab
Ride:  S13
Rep Power: 15 brettII is off the scale
Send a message via AIM to brettII
not really, its jsut what the pump can handle/put out...and in this case (with a h series it may be a good idea).
the distributor will not work on the motor if it is a JDM motor, in this case use a 1994 LS distributor cap if its a usdm motor then you are ok to go. just make sure the wiring is correct and you should have 0 problems
brett
brettII is offline   Reply With Quote
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
H22 Into 99 Civic Hatch. Any problems? 99civichatch HYBRID -> EG-EK / DC 2 04-05-2004 10:32 AM
h22 mounts for 92-95 civic minirek Parts: For Sale/Trade/Wanted 9 02-23-2004 11:55 PM
Decoding VIN Numbers pissedoffsol General Tech Articles 0 01-11-2004 08:48 PM
H22 Into A 99 00 Civic hunter11 HYBRID -> EG-EK / DC 5 02-28-2003 07:04 PM
