Banned
Ride: 92 Prelude Si(retired temporarily) & 92 Civic Hatch
I am having an issue with my passenger side axle on my h22 swapped eg hatch, the axle won't go the whole way in the trans therefore i'm only driving on the driver axle not both, any suggestions or ways to get around this would be great, thanks all...
#7 |
Ride: dc5,mk4 gti,2nd gen civic,92 accord cp,88 crx hf
yea i dont like that type of setup i like using the 90-93 accord intermediate shaft with 90-93 integra lx axles. if your using 94+ integra axles then you still have the stock intermediate shaft witch is ok, im not sure why its doing that though ill try to figure it out
#8 |
Banned
the intermediate shaft is fine thats the side i have NO problem with, its the passenger axle that wont go into the trans far enough to catch, its to short....
#10 |
hmmm i always thought that the teg axles work fine in that swap
2002 Honda Civic Si Greddy Turbo'd 1989 BMW 328ci SR20DET Powered 1972 Honda CB350 Supersport 1971 Mercedes Benz 300sel 6.3 Monster 1989 Dodge Colt/Mitsubishi Mirage Turbo 4g63 Turbo'd -- goodbye, you will be missed ![]() www.thetunersource.com |
#11 |
I had problems with the passenger side axle popping out on my swap when I first got it as well. I was told that the input shaft is different lengths from the prelude to the integra so that the clip is not allowed to seat. I switched over to the Hasport axles when I changed the clutch and haven't had a problem with them since. From what I know you can also take the input portion of the prelude axle and put it onto the integra axle to make a hybrid that would work.
| b16 in 97ex = problem after problem | terribl3jon | HYBRID -> EG-EK / DC | 3 | 03-23-2009 03:42 PM |
| Which is the problem? | m90polk | Civic and CRX - EF | 4 | 06-10-2008 09:57 PM |
| Toe Problem | jimboburgess | Wheels / Suspension / Tires / Brakes | 7 | 05-01-2006 04:45 PM |
| maybe ecu problem | j954drgsr | General Tech and Maintenance | 1 | 01-14-2005 06:55 PM |
| vss problem | smashed4thgen | HYBRID -> ED-EF / DA | 8 | 02-24-2004 12:02 AM |
