Hey, just a quick question. I got a h22 jdm in my 97 EK. Recently I just change the spark plugs and wires and it started to sputter on me. I was wondering could it be the gap size. I have mine set at .044 right now. If thats the problem should I go smaller or bigger?
Ride: 88 Honda Civic HB
What plugs are you using?
I wouldn't get bigger than .044, smaller. I've seen some guys run .032-.038 __________________
Does the part number end with -11? If so, you shouldn't really have too.
Did you make sure the firing order is correct and all grounds are good? __________________
#5 |
No it doesn't end with -11. Hm, I check all the wires and ground see if there is any loose wires/plugs but I didn't find any. My firing order is right. When I changed the plugs/wire it worked for like a day without sputtering but then it just started to sputter again.
#6 |
It's a stock motor? Maybe it could be something else making it sputter(fuel filter or clogged injectors?).
Definitely try a .038 gap and see if that helps(that's I usually run .036 or .038 on all my non-11 NGK's). __________________
| spark plug | carlitoswaypr | RSX | 16 | 06-16-2008 10:38 AM |
| Spark Plug | CiViC_SOHC | Civic and del Sol - EG and EK | 2 | 07-23-2007 04:14 PM |
| oil on #3 spark plug | 94_gs-r | Engine Building | 4 | 01-09-2007 05:02 AM |
| Which spark plug to use??? | Som1Dies2Nite | HYBRID -> ED-EF / DA | 1 | 06-04-2005 06:57 PM |
| Spark Plug HELP!!!!! | Riceburner | General Tech and Maintenance | 5 | 03-26-2004 07:35 PM |
