H22 into civic EG swap
Old 12-09-2006, 05:54 PM   #1
Ride:  Civic EG hatchback
Rep Power: 7 H-Ridah is on a distinguished road
Send a message via Skype™ to H-Ridah
Exclamation H22 into civic EG swap
Hi,
I read a lotta threads on the H22 swap but some things are still unclear to me. I put a list together of parts I’ll need for my swap into my EG Civic. I’m not sure about some of the parts so here goes:
1.Prelude Front Clip (Can get it for like $ 1800)
2.Front and Rear GSR Brakes
Will the GSR brakes work with my stock civic lines or will I need the whole brake “system”?
3.GSR Fuel pump/Prelude Fuel pump
I thought of the GSR fuel pump. Will this work with the H22? Does the Prelude Pump fit in my civic?
4.H Series Rear Engine Bracket
5.H Series a/c Bracket
6.Hasport Engine Mounts
Will GSR mounts work or do I really need aftermarket mounts?
7.Hasport Axels/GSR Axels
I’m not sure if the stick GSR axels will hold up well enough.
8.GSR Gauge Cluster/Sir gauge Cluster
Or will the prelude cluster fit?
9. Manual to automatic Transmission Bracket (my car is automatic)
10.Prelude or GSR Pedal Assembly
I want to buy a brand new clutch and flywheel for the swap. But I’m not sure if I have to buy them for the lude or the civic. Can someone clear this up for me?. I assume the
Prelude ones.
How much can I lower the car for a good clearing?. Cause I heard that with the H22 it will scrape the ground if the car is too low
Sorry for so many questions.
Thanks
H-Ridah is offline   Reply With Quote
Old 12-09-2006, 06:14 PM   #2
trappd-in-859's Avatar
Rep Power: 15 trappd-in-859 is an unknown quantity at this point
3. Just get a Walbro 255lph fuel pump. It will work perfectly for whatever you plan on doing.
6. You will need aftermarket mounts. B-series mounts won't work on an H-series engine.
Correct on the clutch/flywheel.
I'd say maybe an inch- inch and a half. Make sure you get stiffer springs for the front so you wont bottom out so easy.
trappd-in-859 is offline   Reply With Quote
Old 12-09-2006, 06:29 PM   #3
Thanks for the advice dude. Any suggestions on springs?
And how do I recognize stiffness when buying springs?
H22 / '99 Civic - Mystery of the missing RPM Output Wire Dr Tweak HYBRID -> EG-EK / DC 17 05-08-2008 04:14 PM
97 civic dx h22 swap bizzy Engine Building 1 09-21-2003 10:17 PM
Chassis Code VSMB16A2 General Tech and Maintenance 10 01-22-2003 05:32 PM
H22 Swap In Civic Coupe civicblazin101 HYBRID -> EG-EK / DC 1 01-09-2003 10:19 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
